Icemaker stopped working a few days ago. Water works fine, and we just changed filter. Indicator flashes twice then pause, but switches to solid red when flapper is pushed in. I had taken the ice bin out to empty and rinse just before the issue, plus left it out about an hour to thaw and dry before replacing. It snaps back in and I can't see any other apparent issues. Ice cube tray is empty, so water is not going in to make new cubes.
Any other obvious things I can check before I call a repair person? Wondering if something is out of alignment and breaking the beam, or if something "froze up" in the water line while ice bin was out - I have no idea, know nothing about icemakers beyond what I've read on other threads!
