Discuss
ice dam over drain hole causing poor cooling?
 in
Refrigerator & Freezer Repair
Hopefully Gene can help me out here, I posted another question under the "freezer fine, fridge not cold"
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ice dam over drain hole causing poor cooling?
  #1 (permalink)
Old 01-14-2009, 08:32 AM
dtrthesignguy dtrthesignguy is offline
Junior Member
dtrthesignguy is on a distinguished road
Default ice dam over drain hole causing poor cooling?
Model Number: 67-263RI   Brand: Gibson   Age: More than 10 years
Hopefully Gene can help me out here, I posted another question under the "freezer fine, fridge not cold" sticky tab. But that was before I developed my Hypothesis.
Quick run down and hypothesis:
Old Gibson "frost clear" fridge, freezer on top, freezer fine, food compartment too warm.
Took apart and found an Ice dam in the drain trough covering the drain hole.
Defrosted unit with a hair dryer, reassembled, restarted cooled fine for a month. then got warm again. Took apart and exactly the same issue, this time I noticed a foil wrap around trough with wires, A trough heater. I am assuming a bad one at that. all other defrost components seem to be fine.
Heres the hypothesis. Please interject if I am wrong.
The cold air funnels through an unobstructed(no damper) passage from beside the coils down to the food compartment. There is no venting other then the evaporater drain which actually goes through the refrigerator compartment ceiling directly into a drain cup and out the back. My theory is that when this drain hole plugs with ice, the cold air has no way to circulate into the food compartment, Unless the obvious(fridge door is open). With the drain clear and unobstructed, the food compartment chills like mad.
Now with the problem explained. Is the trough heater itself all to blame?
Or is there a possibility of something else like defrost thermostat?
I am assuming parts for this old girl are going to be tough if not impossible to find, but I would sure like to try something as this fridge is an odd size and fits just perfectly where it is and has always run so cheaply and well.
One fix I read from one of your volunteer techs, is that to extend a piece of #12 bare copper wire into the drain hole thats wrapped to the bare copper coil heater above. It was said that this works well. What say you about that for a quick cheap fix? Or on the other hand is there a universal heater of some sort I could install in place of the old foil trough heater?
Thanks in advance
David
Related Models
Hoover 671 Frigidaire Canada/electric Range
Admiral 671AH Range - F/s Std Gas
Admiral 671AH-K Range - F/s Std Gas
Admiral 671WH Range - F/s Std Gas
Admiral 671WH-K Range - F/s Std Gas
Admiral 673AJ-KV Range - F/s Std Gas
Admiral 673WJ-KV Range - F/s Std Gas
Admiral 674AJ-EKLVW Range - F/s Cont Clean Gas
Admiral 674AJ-EKVW Range - F/s Std Gas
Admiral 674AJ-EKW Range - F/s Std Gas
Admiral 674WJ-EKLVW Range - F/s Cont Clean Gas
Admiral 674WJ-EKVW Range - F/s Std Gas
Admiral 674WJ-EKW Range - F/s Std Gas
Admiral 675AJ-KVW Range - F/s Std Gas
Admiral 675AK-KLVW Range - F/s Cont Clean Gas
Admiral 675AK-KVW Range - F/s Std Gas
Admiral 675AM-KSVW Range - F/s Std Gas
Admiral 675LM-KSVW
Admiral 675WJ-KVW Range - F/s Std Gas
Admiral 675WK-KLVW Range - F/s Cont Clean Gas
Admiral 675WK-KVW Range - F/s Std Gas
Admiral 675WM-KSVW Range - F/s Std Gas
Admiral 676AJ-KSVW Range - F/s Std Gas
Admiral 676AK-KLSVW Range - F/s Cont Clean Gas
Admiral 676AK-KSVW Range - F/s Std Gas
Admiral 676AM-KLSVW Range - F/s Cont Clean Gas
Admiral 676AM-KSVW Range - F/s Std Gas
Admiral 676WJ-KSVW Range - F/s Std Gas
Admiral 676WK-KLSVW Range - F/s Cont Clean Gas
Admiral 676WK-KSVW Range - F/s Std Gas
Admiral 676WM-KLSVW Range - F/s Cont Clean Gas
Admiral 676WM-KSVW Range - F/s Std Gas
Maytag 67C Dryer - Gas
Hoover 68 White Westinghouse/range
Hoover 681
Admiral 684AJ-CKV Range - S/c F/s Gas
Admiral 684WJ-CKV Range - S/c F/s Gas
Admiral 685AJ-CKV Range - S/c F/s Gas
Admiral 685AJ-CKVW Range - S/c F/s Gas
Admiral 685WJ-CKV Range - S/c F/s Gas
Admiral 685WJ-CKVW Range - S/c F/s Gas
Admiral 686AJ-EKSVW Range - S/c F/s Gas
Admiral 686AJ-TKSVW Range - S/c F/s Gas
Admiral 686AK-EKSVW Range - S/c F/s Gas
Admiral 686AM-CKSV Range - S/c F/s Gas
Admiral 686AM-TKS Range - S/c F/s Gas
Admiral 686WJ-EKSVW Range - S/c F/s Gas
Admiral 686WJ-TKSVW Range - S/c F/s Gas
Admiral 686WK-EKSVW Range - S/c F/s Gas
Admiral 686WM-CKSV Range - S/c F/s Gas
Admiral 686WM-TKS Range - S/c F/s Gas
Admiral 687AF-CKVW Range - S/c F/s Gas
Admiral 687AJ-EKZW Range - S/c F/s Gas
Admiral 687AJ-TKSAW Range - S/c F/s Gas
Admiral 687AK-TKSAW Range - S/c F/s Gas
Admiral 687AM-TKSAW Range - S/c F/s Gas
Admiral 687WF-CKVW Range - S/c F/s Gas
Admiral 687WJ-EKZW Range - S/c F/s Gas
Admiral 687WJ-TKSAW Range - S/c F/s Gas
Admiral 687WK-TKSAW Range - S/c F/s Gas
Admiral 687WM-TKSAW Range - S/c F/s Gas
Magic Chef 6892VRA Range - S/c S/i Ele
Magic Chef 6892VRV Range - S/c S/i Ele
Magic Chef 6892VVA Range - S/c S/i Ele
Magic Chef 6892VVV Range - S/c S/i Ele
Magic Chef 6892XRA Range - S/c S/i Ele
Magic Chef 6892XRS Range - S/c S/i Ele
Magic Chef 6892XRW Range - S/c S/i Ele
Magic Chef 6892XVA Range - S/c S/i Ele
Magic Chef 6892XVB Range - S/c S/i Ele
Magic Chef 6892XVS Range - S/c S/i Ele
Magic Chef 6892XVW Range - S/c S/i Ele
Magic Chef 6893VVD Range - S/c S/i Ele
Magic Chef 6893VVV Range - S/c S/i Ele
Magic Chef 6893XVB Range - S/c S/i Ele
Magic Chef 6895VRA Range - S/c S/i Ele
Magic Chef 6895VRV Range - S/c S/i Ele
Magic Chef 6896VVD Range - S/c S/i Ele
Magic Chef 6896VVV Range - S/c S/i Ele
Magic Chef 6896XVB Range - S/c S/i Ele
Magic Chef 6898VRA Range - S/c S/i Ele
Magic Chef 6898VRV Range - S/c S/i Ele
Magic Chef 6898VVA Range - S/c S/i Ele
Magic Chef 6898VVD Range - S/c S/i Ele
Magic Chef 6898VVV Range - S/c S/i Ele
Magic Chef 6898XRA Range - S/c S/i Ele
Magic Chef 6898XRB Range - S/c S/i Ele
Magic Chef 6898XVB Range - S/c S/i Ele
Magic Chef 68HA-3CW Range - S/c S/i Ele
Magic Chef 68HA-3CXW Range - S/c S/i Ele
Magic Chef 68HA-4TVW Range - S/c S/i Ele
Magic Chef 68HA-4TXW Range - S/c S/i Ele
Magic Chef 68HA-6TVW Range - S/c S/i Ele
Magic Chef 68HK-6TXW Range - S/c S/i Ele
Magic Chef 68HN-3CXW Range - S/c S/i Ele
Magic Chef 68HN-4TVW Range - S/c S/i Ele
Magic Chef 68HN-4TXW Range - S/c S/i Ele
Magic Chef 68HN-6TVW Range - S/c S/i Ele
Magic Chef 68HN-6TVW-SC Range - S/c S/i Ele
Hoover 69
Hoover 691
Whirlpool 6ALBR6245JQ2 Automatic Washer
Whirlpool 6ALBR6245MW0 Automatic Washer
Whirlpool 6ALBR6245MW3 Automatic Washer
Whirlpool 6ALSC8255JQ2 Automatic Washer
Whirlpool 6ALSC8255MW0 Automatic Washer
Whirlpool 6ALSC8255MW3 Automatic Washer
Whirlpool 6ALSQ8000JQ1 Automatic Washer
Whirlpool 6ALSQ8000JQ2 Automatic Washer
Whirlpool 6ALSQ8000MW0 Automatic Washer
Whirlpool 6ALSQ8000MW3 Automatic Washer
Whirlpool 6ALSR7244JQ1 Automatic Washer
Whirlpool 6ALSR7244JQ2 Automatic Washer
Whirlpool 6ALSR7244MW0 Automatic Washer
Whirlpool 6ALSR7244MW3 Automatic Washer
Whirlpool 6ALSS5233JQ1 Automatic Washer
Whirlpool 6AMTW5405TQ0 Automatic Washer
Maytag 6AMTW5405TQ0 Automatic Washer
Maytag 6AMTW5855TQ0 Automatic Washer
Whirlpool 6CA2781XWG0
  #2 (permalink)
Old 01-14-2009, 02:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
In order to provide a proper air circulation, there is suppose to be a kind of damper and an air return. The drain hole can not be one of them because if the colder air comes down into the refrigerator this way, there is suppose to be a lot of condensation around, and if warmer air comes up in the freezer through this hole then it will freeze up the hole. That's what probably happens in this case.
I'm not able to provide more specific information because the model number you posted does not come up. You have to find the damper and the air return to solve this problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Poor cooling Pauliner Refrigerator & Freezer Repair 1 09-15-2008 07:27 PM
poor drying paulworld Dryer Repair 1 09-12-2008 08:34 AM
poor heat dstroke Dryer Repair 0 02-17-2008 11:48 AM
stove causing short bevi Oven Repair (including Ranges and Cooktops) 7 08-11-2007 11:39 AM
Poor Cooling / No Cooling WLee Refrigerator & Freezer Repair 3 08-06-2007 06:25 PM
