Discuss
compressor only runs for 30-45 sec
 in
Refrigerator & Freezer Repair
i have a fri. that the compressor only runs for 30-45 sec and then the controller gets hot and shuts
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » compressor only runs for 30-45 sec
  #1 (permalink)
Old 04-11-2011, 08:48 AM
Junior Member
rmills is on a distinguished road
Default compressor only runs for 30-45 sec
Model Number: LFFU1765DW5   Brand: Frigidaire   Age: 5 - 10 years
i have a fri. that the compressor only runs for 30-45 sec and then the controller gets hot and shuts down. I have 120 volts even when the comp stops. Any idea maybe the controller is bad or the run capacitor?
Related Models
Frigidaire LFFU1765DW5 Frigidaire/freezer
Frigidaire LFFU1765DW6 Frigidaire/freezer
Frigidaire LFFU1765DW8 Frigidaire/freezer
Frigidaire LFFU1765DW9 Frigidaire/freezer
Frigidaire LFFU1766GW1 FREEZER
Frigidaire LFFU1766GW2 FREEZER
Frigidaire LFFU1766GW3 FREEZER
Frigidaire LFFU1766GW4 FREEZER
Frigidaire LFFU17F5HWA FREEZER
Frigidaire LFFU17F5HWB FREEZER
Frigidaire LFFU17F5HWC FREEZER
Frigidaire LFFU17F5HWD FREEZER
Frigidaire LFFU17F5HWE FREEZER
Frigidaire LFFU17F5HWF FREEZER
Frigidaire LFFU17F5HWG FREEZER
Frigidaire LFFU17F5HWH FREEZER
Frigidaire LFFU17F5HWJ FREEZER
Frigidaire LFFU17F5HWK FREEZER
Frigidaire LFFU17F5HWL FREEZER
Frigidaire LFFU2065DW0 Frigidaire/freezer
Frigidaire LFFU2065DW1 Frigidaire/freezer
Frigidaire LFFU2065DW10 Frigidaire/freezer
Frigidaire LFFU2065DW2 Frigidaire/freezer
Frigidaire LFFU2065DW3 Frigidaire/freezer
Frigidaire LFFU2065DW4 Frigidaire/freezer
Frigidaire LFFU2065DW5 Frigidaire/freezer
Frigidaire LFFU2065DW6 Frigidaire/freezer
Frigidaire LFFU2065DW7 Frigidaire/freezer
Frigidaire LFFU2065DW8 Frigidaire/freezer
Frigidaire LFFU2065DW9 Frigidaire/freezer
Frigidaire LFFU2067DS0 Frigidaire/freezer
Frigidaire LFGF3014LBA GAS RANGE
Frigidaire LFGF3014LBB GAS RANGE
Frigidaire LFGF3014LBC GAS RANGE
Frigidaire LFGF3014LWA GAS RANGE
Frigidaire LFGF3014LWB GAS RANGE
Frigidaire LFGF3014LWC GAS RANGE
Frigidaire LFGF3022LSA GAS RANGE
Frigidaire LFGF3022LSB GAS RANGE
Frigidaire LFGF3022LSC GAS RANGE
Frigidaire LFGF3022LSD GAS RANGE
Frigidaire LFGF3022LWA GAS RANGE
Frigidaire LFGF3022LWC GAS RANGE
Frigidaire LFGF3027LBA GAS RANGE
Frigidaire LFGF3027LBB GAS RANGE
Frigidaire LFGF3027LSA GAS RANGE
Frigidaire LFGF3027LSB GAS RANGE
Frigidaire LFGF3027LSC GAS RANGE
Frigidaire LFGF3027LWA GAS RANGE
Frigidaire LFGF3027LWB GAS RANGE
Frigidaire LFHI1826LB0 REFRIGERATOR
Frigidaire LFHI1826LM0 REFRIGERATOR
Frigidaire LFHI1826LW0 REFRIGERATOR
Frigidaire LFHT1513LB0 REFRIGERATOR
Frigidaire LFHT1513LB1 REFRIGERATOR
Frigidaire LFHT1513LB2 REFRIGERATOR
Frigidaire LFHT1513LB3 REFRIGERATOR
Frigidaire LFHT1513LB4 REFRIGERATOR
Frigidaire LFHT1513LB5 REFRIGERATOR
Frigidaire LFHT1513LW0 REFRIGERATOR
Frigidaire LFHT1513LW1 REFRIGERATOR
Frigidaire LFHT1513LW2 REFRIGERATOR
Frigidaire LFHT1513LW3 REFRIGERATOR
Frigidaire LFHT1513LW4 REFRIGERATOR
Frigidaire LFHT1513LW5 REFRIGERATOR
Frigidaire LFHT1713LB0 REFRIGERATOR
Frigidaire LFHT1713LB1 REFRIGERATOR
Frigidaire LFHT1713LB2 REFRIGERATOR
Frigidaire LFHT1713LB3 REFRIGERATOR
Frigidaire LFHT1713LQ2 REFRIGERATOR
Frigidaire LFHT1713LQ3 REFRIGERATOR
Frigidaire LFHT1713LW0 REFRIGERATOR
Frigidaire LFHT1713LW1 REFRIGERATOR
Frigidaire LFHT1713LW2 REFRIGERATOR
Frigidaire LFHT1713LW3 REFRIGERATOR
Frigidaire LFHT1817LB0 REFRIGERATOR
Frigidaire LFHT1817LB1 REFRIGERATOR
Frigidaire LFHT1817LB2 REFRIGERATOR
Frigidaire LFHT1817LB3 FRIGIDAIRE/REFRIGERATOR
Frigidaire LFHT1817LB4 REFRIGERATOR
Frigidaire LFHT1817LF0 REFRIGERATOR
Frigidaire LFHT1817LF1 REFRIGERATOR
Frigidaire LFHT1817LF2 REFRIGERATOR
Frigidaire LFHT1817LF3 FRIGIDAIRE/REFRIGERATOR
Frigidaire LFHT1817LF4 REFRIGERATOR
Frigidaire LFHT1817LR1 REFRIGERATOR
Frigidaire LFHT1817LR2 REFRIGERATOR
Frigidaire LFHT1817LR3 FRIGIDAIRE/REFRIGERATOR
Frigidaire LFHT1817LR4 REFRIGERATOR
Frigidaire LFHT1817LW0 REFRIGERATOR
Frigidaire LFHT1817LW1 REFRIGERATOR
Frigidaire LFHT1817LW2 REFRIGERATOR
Frigidaire LFHT1817LW3 FRIGIDAIRE/REFRIGERATOR
Frigidaire LFHT1817LW4 REFRIGERATOR
Frigidaire LFHT2117LB0 REFRIGERATOR
Frigidaire LFHT2117LB1 REFRIGERATOR
Frigidaire LFHT2117LW0 REFRIGERATOR
Frigidaire LFHT2117LW1 REFRIGERATOR
Frigidaire LFHT2117LW2 REFRIGERATOR
 LFN480CE Air Conditioner
Frigidaire LFTR1512LW0 REFRIGERATOR
Frigidaire LFTR1814LB0 REFRIGERATOR
Frigidaire LFTR1814LB1 REFRIGERATOR
Frigidaire LFTR1814LB2 REFRIGERATOR
Frigidaire LFTR1814LB3 REFRIGERATOR
Frigidaire LFTR1814LB4 REFRIGERATOR
Frigidaire LFTR1814LB6 REFRIGERATOR
Frigidaire LFTR1814LW0 REFRIGERATOR
Frigidaire LFTR1814LW1 REFRIGERATOR
Frigidaire LFTR1814LW2 REFRIGERATOR
Frigidaire LFTR1814LW3 REFRIGERATOR
Frigidaire LFTR1814LW4 REFRIGERATOR
Frigidaire LFTR1814LW5 REFRIGERATOR
Frigidaire LFTR1814LW6 REFRIGERATOR
 LFU480CE Air Conditioner
Frigidaire LFUH21F7LM0 FREEZER
Frigidaire LFUH21F7LM1 FREEZER
Frigidaire LFUH21F7LM2 FREEZER
Frigidaire LFUS2613LE0 REFRIGERATOR
Frigidaire LFUS2613LE1 REFRIGERATOR
  #2 (permalink)
Old 04-12-2011, 03:59 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
If there is voltage to the compressor when it shuts down, you have a bad compressor. Usually terminal for even a decent refrigerator, too expensive to fix, might want to get it checked by a pro.
__________________
  #3 (permalink)
Old 04-12-2011, 09:42 AM
Junior Member
Default
there is voltage there but i just have no idea what they call a compressor controller and what it does. it is a replaceable part little black box with the run capacitor mounted to it also. There are 3 prongs on the compressor itself and have again no idea which 2 are power.
  #4 (permalink)
Old 04-12-2011, 02:42 PM
Senior Expert
APP Volunteer
Default
Your compressor is probably failing, drawing excessive current, then shutting down on the overload device inside the controller. An amprobe would confirm this. Also, if the compressor takes a rather long time to re-start, that would confirm it.
You can try a new controller, really a start device with internal overload klixon AP2113688
Without confirmation, you will probably have an unreliable fridg even with a new start device.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrig fan runs but not compressor mjq1987 Refrigerator & Freezer Repair 0 08-30-2010 05:56 AM
fan runs,compressor hot doesnt run mark f Refrigerator & Freezer Repair 4 03-17-2010 10:28 AM
compressor runs or won't start yar Refrigerator & Freezer Repair 6 11-14-2009 03:54 PM
refridgerator not cooling but compressor runs bpetska Refrigerator & Freezer Repair 3 06-16-2009 06:15 PM
Compressor runs only 15 seconds MartyM Refrigerator & Freezer Repair 1 05-11-2009 12:31 PM
