| » defrost timer ap4246797 |
Here is your parts breakdown
Model Search Look in the "Compressor Parts" section Item 38. Not sure on the Item # hard to see it.
__________________
Have never seen one in the freezer compartment.
Usually when they are place in the compressor compartment under the fridge they are just behind the kick plate or just behind the rear grill. This allows easy access if you want to manually force a defrost cycle. What you may see is just a bracket/plate with a hole in it. Behind the hole will be the cam to manually rotate the timer. Other that that I am stumped.
__________________
hi again, i found, down in the left hand corner a plate with a hole in it. with a black plastic piece behind it. 2 screws on the front of the frig and one on the side of the plate. i removed all 3 screws, but can't get the plate to come out. i think maybe that black plastic piece may be it. if i could turn the frig on its back and get it from underneath would be easier. any idea how to get this plate off.
Thank you so much for all your help, i hate to keep bothering you. thank goodness everyone isn't this much trouble. Thanks j |
| Display Modes | |
| Does my Maytag have a defrost timer or adaptive defrost control? Where is it? | Momto8 | Refrigerator & Freezer Repair | 13 | 06-18-2012 06:37 PM |
| I still have froze in the freezer after changing defrost timer & bi-metal defrost | matteson | Refrigerator & Freezer Repair | 0 | 12-29-2009 06:25 PM |
| Defrost timer only works in defrost cycle | george10 | Refrigerator & Freezer Repair | 2 | 07-18-2009 06:15 PM |
| defrost timer | hairless15006 | Refrigerator & Freezer Repair | 2 | 05-01-2009 04:34 PM |
| Where is the defrost timer!? Please Help | Ved1975 | Refrigerator & Freezer Repair | 1 | 04-27-2009 09:13 PM |
