| » Refrigerator not cold enough |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Brand: Kenmore Age: 1 - 5 years
I have a bottom freezer refrigerator. I have the fridge set at the coldest setting, but it does not get colder than 40 degrees and most of the time is higher than that. It doesn't seem to run enough, it shuts off before it gets cold. The freezer runs fine.
Hi mfd
In order to provide the most accurate advise I need the complete model number of your fridge. Gene.
__________________
Professional appliance repair services in Orange County, California. |
The first thing I would do is check the back panel inside the freezer. If it's covered with a snow then there is a problem with the defrost system. Also check if the evaporator fan is working properly. The fan is located behind the back cover in the freezer and should run when the compressor is running.
Let me know what you found. Gene.
__________________
Check the damper control in the fresh food compartment now. The gate should be open if the temperature is too warm. If the gate is closed replace the dumper control. Also check for any blockage in the air exchange window.
- The part number for the damper control AP100860 The damper control Good luck. Gene.
__________________
My refrigerator has been closed all night, I just checked the temperature in the fridge, it is 42 degrees. I have the dial turned to as cold as possible, and the fridge is not running right now. It dosen't seem to run enough.
if the the thermostat is not solid state ,an is the old style thermostat with a sensing bulb ,it can be adjusted to be colder,looking at the thermostat close up, there a small screw which when turned counter clockwise will make the unit [fridge] colder. Only turn this screw no more then 1/8 to 1/4 of a turn. Also check to see if the light is not staying on when door is closed.lol.
__________________
| Display Modes | |
| GE Refrigerator is warm freezer is cold !! | Steve705 | Refrigerator & Freezer Repair | 1 | 10-07-2007 12:24 PM |
| Fridge & Freezer Cycle Cold To Warm Back To Cold | terkel | Refrigerator & Freezer Repair | 1 | 09-25-2007 02:58 AM |
| Freezer has frost and cold/frig is not very cold | DinATL | Refrigerator & Freezer Repair | 1 | 09-14-2007 07:38 PM |
| Freezer cold, refrigerator cool | barthayden | Refrigerator & Freezer Repair | 0 | 08-23-2007 04:43 PM |
| freezer fine, refrigerator not cold | fargnoli | Refrigerator & Freezer Repair | 0 | 08-08-2007 09:24 PM |
