The ice maker is leaking water quite often but not on every cycle.When it leaks it might just drip or might come out all over the place. There is a screw adjustment for a switch that seems to control the amount of water that comes into the ice cube maker area. I have tried cutting down the input amount of water to see what affect that may have but it still dripped water. Could my valve be bad intermmitently? Is there a way to rebuild or repair the ice maker?:confused:
