Discuss
fridge not working
 in
Refrigerator & Freezer Repair
i really need help with this my refrigerator is not working but the freezer side is i cleand all around
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » fridge not working
  #1 (permalink)
Old 10-29-2007, 09:55 AM
rmojon1976 rmojon1976 is offline
Junior Member
rmojon1976 is on a distinguished road
Default fridge not working
Model Number: LSD2615HEZ   Brand: Admiral   Age: 1 - 5 years
i cleand all around the bootom of fridge coils everything
now the knob to adjust and set to a colder temp i dont think its working
even if i set it to high or low i dont hear anything turning on or air blowing in the refrigerator side
please help me
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-29-2007, 10:39 AM
fixxit fixxit is offline
Senior Expert
APP Volunteer
fixxit is on a distinguished road
Default
not sure if this is a side by side as the modle # doesn't seem to come up. however, this could be a defrost/ evap fan problem. empty out the freezer and check the evaperator by removing the evaporator cover in the back of the freezer . if it is completly iced over, it is not allowing airflow to the refer, and you have a defrost problem (defrost timer, defrost heater, or defrost bi-metal). if the evaperator fan isnt blowing (will also not allow airflow) then you may have a bad evaporator fan motor. good luck and post your results
  #3 (permalink)
Old 10-29-2007, 11:39 AM
Junior Member
Default
the fan is working its a little fan under the fridge
it is a side by side unit
is the freezer cover behind the ice crushing unit ?
where is the defrost timer set ?
i know there is a temp control unit on the fridge side
but on the freezer all i find is a metal box that hold the motor for crushing ice
please advice
  #4 (permalink)
Old 10-29-2007, 11:51 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi
In order to provide the most accurate advise I need the complete model number of your fridge.
__________________
Professional appliance repair in Los Angeles, California.
  #5 (permalink)
Old 10-29-2007, 12:05 PM
Junior Member
Default
the model number is LSD2615HE
im sorry i wrote a z at the end of the other model number
but this one is the correct one
  #6 (permalink)
Old 10-29-2007, 12:08 PM
Junior Member
Default
here are the specs
Model Number: LSD2615HE* Style: Side-by-Side w/Ice thru door
Brand: ADMIRAL Defrost: Automatic
Manufacturer: MAYTAG APPLIANCES - AMANA REFRIG. PROD. Built-in Ice Maker: Yes
Access Type: Door
Capacity and Size Measures
Fresh Food Volume: 15.83 (cu. ft.) Height: 70 (inches)
Freezer Volume: 9.77 (cu. ft.) Width: 36 (inches)
Total Volume: 25.6 (cu. ft.) Depth: 34 (inches)
Energy Efficiency
  #7 (permalink)
Old 10-29-2007, 12:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
As per fixxit previous advise, I would recommend to check first for snow built up on the back cover inside the freezer and performance of the evaporator fan, located behind the back cover in the freezer. The fan should run when the compressor is running.
Let me know what you found.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge & Freezer not working tgammons Refrigerator & Freezer Repair 1 10-08-2007 04:32 AM
Fridge & Freezer not working tgammons Refrigerator & Freezer Repair 0 10-07-2007 01:25 PM
Fridge / Freezer stopped working cardinco Refrigerator & Freezer Repair 2 10-05-2007 07:06 PM
Kitchen Aid Fridge KSCS25FKSS00 is freezing on the fridge size shawnharper Refrigerator & Freezer Repair 0 09-03-2007 11:27 PM
Fridge not working jamie7 Refrigerator & Freezer Repair 0 08-12-2007 09:08 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
