Discuss
water dispenser
 in
Refrigerator & Freezer Repair
Water dispenser does not turn off when glass is removed. What part needs to be replaced?
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » water dispenser
  #1 (permalink)
Old 10-29-2007, 09:50 AM
lakedout lakedout is offline
Junior Member
lakedout is on a distinguished road
Default water dispenser
Model Number: KSRS251HWH02   Brand: Kitchen Aid   Age: 5 - 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-29-2007, 01:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi lakedout
To find out exactly which part is bad - the water valve coil or the switch in the water dispenser you should run a pretty simple test.
You'll need a second person to help you.
Locate the water inlet valve on the back of the fridge and the coil for the water dispenser. (The water line for the water dispenser should be 5/16").
Depress and release the water dispenser lever and remove the electrical plug from the coil.
If water stopped right after you removed the plug then the water inlet valve has to be replaced. If not then the problem is a bad switch in the water dispenser.
- The part number for the water inlet valve AP3160649
- The part number for the switch AP3131893
- Here are the break down diagrams for the Kitchen Aid refrigerator Model KSRS25IHWH02
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 10-30-2007, 12:18 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
From lakedout's email:
"Hi Gene:
Many thanks. I believe it is the switch since the icemaker continues to function OK."
  #4 (permalink)
Old 11-03-2007, 08:33 AM
Junior Member
Gene FYI:
Problem was not the switch nor the valve - it was air in the plastic loop storage (behind the refrigerator bottom meat drawer). After I eliminated the air pockets, the dispenser works fine.
  #5 (permalink)
Old 11-18-2007, 06:04 PM
supra24valve supra24valve is offline
Junior Member
supra24valve is on a distinguished road
Default
How did you get the air out?
  #6 (permalink)
Old 11-19-2007, 09:28 AM
Junior Member
Just bleed the water line - be sure to use a large container, as it may take a while!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice and water dispenser birdsac Refrigerator & Freezer Repair 0 10-28-2007 06:59 AM
No Water or Ice in the dispenser mrlang Refrigerator & Freezer Repair 0 10-22-2007 06:47 AM
Water Dispenser Dripping Carr Boy Refrigerator & Freezer Repair 4 10-13-2007 05:36 AM
water/ice dispenser schumske Refrigerator & Freezer Repair 2 10-10-2007 04:26 PM
ice dispenser working...water dispenser not rishuk Refrigerator & Freezer Repair 0 09-25-2007 04:03 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
