we had a power problem a couple days ago the power went off then came back on several times then the fridge stoped working the lights inside are working and nothing eles on the front control panel the cubed ice light is blinking and no other lights are on please help what can fix this problem
Originally Posted by: traceall8 we had a power problem a couple days ago the power went off then came back on several times then the fridge stoped working the lights inside are working and nothing eles on the front control panel the cubed ice light is blinking and no other lights are on please help what can fix this problem by the way changed main control board that didnt fix the problem any suggestions on what next transformer? display panel?
Originally Posted by: traceall8 we had a power problem a couple days ago the power went off then came back on several times then the fridge stoped working the lights inside are working and nothing eles on the front control panel the cubed ice light is blinking and no other lights are on please help what can fix this problem please help we replaced control board that didnt fix the problem what eles could it be front control panel or what????
