Discuss
Jenn Air JSD2789DEB nto cooling correctly
 in
Refrigerator & Freezer Repair
It all started when I noticed the fridge getting warmer. The freezer "seemed" fine, but it was hard
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Jenn Air JSD2789DEB nto cooling correctly
  #1 (permalink)
Old 01-11-2009, 04:14 PM
zrxoa1 zrxoa1 is offline
Junior Member
zrxoa1 is on a distinguished road
Default Jenn Air JSD2789DEB nto cooling correctly
Model Number: JSD2789DEB   Brand: Jenn-Air   Age: 5 - 10 years
It all started when I noticed the fridge getting warmer. The freezer "seemed" fine, but it was hard to tell. I pulled off the back panel and found the condenser fan motor was not running. I removed it and checked it and it appeared bad. Also, the shaft was very hard to turn. So I ordered a new motor...
Got the new motor and noticed the shaft turned VERY easily, so I installed it, plugged the fridge in a voila, it started right up. I thought the problem was solved, but after 2 days of letting it run (fridge had been off for a few days and was down to room temperature) it seemed it was not getting cold on the fridge side and the freezer side felt like the fridge side USED to feel...
I realized I did not feel any air moving into the fridge or out of the top vents behind the icemaker. So I removed the rear panels and found the evap fan was not running.
At this point I called in a repair shop. The guy came in, said the evap fan motor was bad and began to replace it. After replacing the fan motor, the evap fan started right up.
I was charged $187.50 for the part and the R/R of the part, which I think was a rip off...
Anyway, 2 days after the evap fan motor being replaced, the temps are still not right. It will barely make ice (2 batches in 4 days) and fluctuates between fridge coldness and almost freezing things...
At this point I am lost.... compressor, freon leak, thermostat, defroster??
Need help.... getting ready to buy new fridge if the experts think this one is done.
Related Models
Jenn-Air JSD2789DEB Ref - SXS/I&W
Jenn-Air JSD2789DEQ Ref - SXS/I&W
Jenn-Air JSD2789DES Ref - SXS/I&W
Jenn-Air JSD2789DEW Ref - SXS/I&W
Jenn-Air JSD2789GEB Ref - SXS/I&W
Jenn-Air JSD2789GEQ Ref - SXS/I&W
Jenn-Air JSD2789GES Ref - SXS/I&W
Jenn-Air JSD2789GEW Ref - SXS/I&W
Jenn-Air JSD2789HEB Ref - SXS/I&W
Jenn-Air JSD2789HES Ref - SXS/I&W
Jenn-Air JSD2789HEW Ref - SXS/I&W
Jenn-Air JSD2989AEA Ref - SXS/I&W
Jenn-Air JSD2989AEB Ref - SXS/I&W
Jenn-Air JSD2989AEW Ref - SXS/I&W
Jenn-Air JSM900DAAP Small Appliances
Jenn-Air JSM900DAAS Small Appliances
Jenn-Air JSM900EAAB Small Appliances
Jenn-Air JSM900EAAN Small Appliances
Jenn-Air JSM900EAAS Small Appliances
Jenn-Air JSM900EAAU Small Appliances
Jenn-Air JSM900EAAW Small Appliances
Jenn-Air JSM900GAAU Small Appliances
Jenn-Air JSM900HAAW Small Appliances
Jenn-Air JSM900LAAW Small Appliances
Jenn-Air JSM900RAAS Small Appliances
Jenn-Air JSM900RAAW Small Appliances
Jenn-Air JSM900TAAU Small Appliances
Jenn-Air JSM900XAAB Small Appliances
Jenn-Air JSM900XAAN Small Appliances
Jenn-Air JSM900XAAP Small Appliances
Jenn-Air JSM900XAAS Small Appliances
Jenn-Air JSM900XAAU Small Appliances
Jenn-Air JSM900XAAW Small Appliances
Jenn-Air JSM900YAAS Small Appliances
Jenn-Air JSM900ZAAU Small Appliances
Maytag JSP18 Commercial Cooking
Maytag JSP182 Commercial Cooking
General Electric JSP23*02 Electric range
Maytag JSP24 Commercial Cooking
General Electric JSP26BD1AD Electric range
General Electric JSP26BD1CT Electric range
General Electric JSP26BD1WH Electric range
General Electric JSP26BD2AD Electric range
General Electric JSP26BD2CT Electric range
General Electric JSP26BD2WH Electric range
General Electric JSP26BD3WH Electric range
General Electric JSP26BW1AD Electric range
General Electric JSP26BW1WH Electric range
General Electric JSP26BW2AD Electric range
General Electric JSP26BW2WH Electric range
General Electric JSP26BW3AD Electric range
General Electric JSP26BW3WH Electric range
General Electric JSP26BW4AD Electric range
General Electric JSP26BW4WH Electric range
General Electric JSP26GN1 Electric range
General Electric JSP26GN2 Electric range
General Electric JSP26GP1 Electric range
General Electric JSP26GP2AD Electric range
General Electric JSP26GP2WH Electric range
General Electric JSP26GP3AD Electric range
General Electric JSP26GP3WH Electric range
General Electric JSP26GP4AD Electric range
General Electric JSP26GP4WH Electric range
General Electric JSP26GT1AD Electric range
General Electric JSP26GT1WH Electric range
General Electric JSP26GV1AD Electric range
General Electric JSP26GV1WH Electric range
General Electric JSP27*02 Electric range
General Electric JSP27*05 Electric range
General Electric JSP27*D1 Electric range
General Electric JSP27*D3 Electric range
General Electric JSP27*J1 Electric range
General Electric JSP27*J2 Electric range
General Electric JSP27*J3 Electric range
General Electric JSP27*J4 Electric range
General Electric JSP27*J5 Electric range
General Electric JSP27*J6 Electric range
General Electric JSP28G*02 Electric range
General Electric JSP28G*05 Electric range
General Electric JSP28G*D1 Electric range
General Electric JSP28G*D3 Electric range
General Electric JSP28G*H1 Electric range
General Electric JSP28G*H2 Electric range
General Electric JSP28G*J1 Electric range
General Electric JSP28G*J2 Electric range
General Electric JSP28G*J3 Electric range
General Electric JSP28G*J4 Electric range
General Electric JSP28G*J5 Electric range
General Electric JSP28G*J6 Electric range
General Electric JSP28G*J7 Electric range
General Electric JSP28GN1 Electric range
General Electric JSP28GN2 Electric range
General Electric JSP28GP1 Electric range
General Electric JSP28GP2BG Electric range
General Electric JSP28GP3BG Electric range
General Electric JSP28GP4BG Electric range
General Electric JSP28GT1BB Electric range
General Electric JSP28GV1BB Electric range
General Electric JSP31GN1 Electric range
General Electric JSP31GN2 Electric range
General Electric JSP31GP1 Electric range
General Electric JSP31GP2WH Electric range
General Electric JSP31GP3WH Electric range
General Electric JSP31GP4WH Electric range
General Electric JSP31WT1WW Electric range
General Electric JSP31WV1WW Electric range
General Electric JSP34AV1AA Electric range
General Electric JSP34AW1AA Electric range
General Electric JSP34AW2AA Electric range
General Electric JSP34AW3AA Electric range
General Electric JSP34AW4AA Electric range
General Electric JSP34BD1BB Electric range
General Electric JSP34BD2BB Electric range
General Electric JSP34BD3BB Electric range
General Electric JSP34BW1BB Electric range
General Electric JSP34BW2BB Electric range
General Electric JSP34BW3BB Electric range
General Electric JSP34BW4BB Electric range
General Electric JSP34CD1CC Electric range
General Electric JSP34CD2CC Electric range
  #2 (permalink)
Old 01-11-2009, 05:18 PM
Junior Member
Default
Could really use some help here folks....
  #3 (permalink)
Old 01-12-2009, 04:20 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Make sure both fans are running and the condenser (#9 on the break down diagram) is clean. Remove the rear panel in the freezer and check how the evaporator coil is covered with snow. Normally it suppose to be 100% covered with light snow. Post the results.
Here are the break down diagrams for the Jenn Air refrigerator Model JSD2789DEB
__________________
  #4 (permalink)
Old 01-12-2009, 08:22 PM
Junior Member
Default
I have cleaned the condenser coils already. The evaporator is 100% free of any frost or "snow" except for the tube closest to the fan, it is HEAVILY covered...
My wife just told me the condenser motor has stopped running for a bit... freezer side is getting warmer. Whe it does run, BOTH fans (cond and evap) ar running.
Is it dead?
  #5 (permalink)
Old 01-12-2009, 08:26 PM
Junior Member
Default
Gene.. can you also take a look here... GE Profile top load... will not agitate
  #6 (permalink)
Old 01-13-2009, 08:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the system is low on Freon (leak somewhere) or the compressor has low capacity. You have to call a certified technician in that case and it could be a costly repair.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air cooling fan dat Oven Repair (including Ranges and Cooktops) 0 11-23-2008 11:12 AM
Not functioning correctly ResLtFire517 Refrigerator & Freezer Repair 1 10-14-2008 08:18 PM
Dryer not heating correctly scottwood1 Dryer Repair 1 04-14-2008 07:04 AM
does not cycle correctly clubkurt Dishwasher Repair 1 02-18-2008 02:51 AM
oven will not heat correctly Jolehouse Oven Repair (including Ranges and Cooktops) 1 12-17-2007 07:21 PM
