Discuss
Help- GE Fridge is dead - compressor?
 in
Refrigerator & Freezer Repair
problem is board ,not relay on compressor, fagetaboutit,
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Help- GE Fridge is dead - compressor?
  #11 (permalink)
Old 01-11-2009, 04:50 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
__________________
  #12 (permalink)
Old 01-11-2009, 05:43 PM
Dhilb Dhilb is offline
Junior Member
Dhilb is on a distinguished road
Default
Finally got the box off the relay - it looks fine. Will be ordering motherboard tonight. Many thanks to all!!
  #13 (permalink)
Old 01-11-2009, 07:03 PM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
Your it man, get it off. I think we are wasting our time. Replace the motherboard. I am done here. All yours Denman. Tom ApplianceEducator.com
  #14 (permalink)
Old 01-11-2009, 09:10 PM
Eddie365 Eddie365 is offline
Member
Eddie365 is on a distinguished road
Default
That black cover on the box attached to the compressor doesn't want to come off - I'm assuming that is covering the relay that Denman is suggesting I check?? Tips on getting it loose?
The black cover is usually hold by a metal clamp around the center, you have to get down to be able to see it. once you get that cover out
you will see the relay, just pull it right out, you may use a flat screw driver be very gentle. look at the connections make sure they are not
burn and look at the 3 proms at the compressor that they don't have
any plastic melt on them.connections look clean replace with a new one. base on what you describe this is the most likely the cause for your compressor not to be running.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer/fridge not cold, compressor hot dgiardina Refrigerator & Freezer Repair 2 01-07-2009 08:15 AM
Kitchenaid Fridge Hummed now dead erickr123 Refrigerator & Freezer Repair 4 11-24-2008 02:25 AM
compressor hot, fridge and freezer not cooling jeansto Refrigerator & Freezer Repair 19 10-29-2008 07:50 AM
Fridge/Freezer Compressor cycling on and off dmeyer4 Refrigerator & Freezer Repair 0 08-07-2008 07:37 PM
Magic Chef Fridge - Compressor won't run agarb Refrigerator & Freezer Repair 2 07-30-2008 10:00 AM
