| » Icemaker bin overflows |
Model Number: KUISNNJB8 Brand: Kitchen Aid Age: 1 - 5 years
My standalone icemaker bin fills up and the icemaker keeps making ice to overflow the bin. I am wondering if the thermostat in the inside of the storage bin could be faulty or if there is could be something else I'm not aware of? Any help would be appreciated.
Quote:
You're probably correct, bad or loose bin thermistor, or control. We could be more informative, with a proper model number off the unit, But here's some basic thermistor information. 1. Unplug ice maker or disconnect power. chart.2. Set the ohmmeter to the appropriate scale. 3. For the most accurate measurement, immerse the thermistor in ice water for 5 minutes, then use the 32°F/0°C reading in the chart. 4. Touch the ohmmeter test leads to the two bin thermistor connectors. The meter should indicate as shown in the following F. C. Ohms Res. 10 (–12) 59,422 - 72,627 50 (10) 18,219 - 22,26732 (0) 30,266 - 36,992 70 (21) 10,280 - 12,564 90 (32) 6,387 - 7,807Too much ice in bin = Defective bin thermistor = Replace thermistor If you have the correct resistance readings, and the connections are good and tight, you'll have to suspect a bad control. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Icemaker water overflows | Capro22340 | Refrigerator & Freezer Repair | 1 | 04-06-2011 07:08 PM |
| Icemaker overflows with water | cmro327 | Refrigerator & Freezer Repair | 0 | 10-12-2010 11:20 PM |
| Icemaker water overflows | ChickenShack | Refrigerator & Freezer Repair | 1 | 04-06-2010 11:53 AM |
| Icemaker water overflows | hhoffman | Refrigerator & Freezer Repair | 0 | 04-06-2010 09:37 AM |
| Icemaker overflows | westmor | Refrigerator & Freezer Repair | 0 | 02-13-2008 11:55 AM |
