Discuss
Stand-a-lone ice maker in failure mode.
 in
Refrigerator & Freezer Repair
My stand-a-lone ice maker goes in to fault mode after making a slab of ice and attempting to cut the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Stand-a-lone ice maker in failure mode.
  #1 (permalink)
Old 04-04-2011, 01:48 PM
Junior Member
bsjones is on a distinguished road
Default Stand-a-lone ice maker in failure mode.
Model Number: model 89582   Brand: Kenmore   Age: Less than 1 year
My stand-a-lone ice maker goes in to fault mode after making a slab of ice and attempting to cut the slab. It goes in to fault mode after staying in harvest mode for more than 16 minutes. I do not get a thermistor error on either the bin or evaporator when running the in clean mode (pretest before entering clean mode). I've unplugged each thermistor and ran the clean mode and the diagnostics recognized that they were removed.
The ice making process looks like it is correct in the fact that the ice looks to be normal size and it is released and slides down on to the cutting grid. The grid only cuts about half way before the 16 min. harvest interval is up and the fault is detected. I've removed the grid and the wire is intact. Resistance is 5 ohms and the voltage across the terminals is about 9.5 volts. You can feel some heat coming off of the grid before the ice slides on to it. It is not a lot of heat as you can place your hand on it. The controls are new, so I do not suspect the controls are the problem. What other elements are in the harvest cycle that could be causing this problem?
Bad thermistor, cutting grid, or transformer?
Related Models
Whirlpool MODEL_PBK0190
Magic Chef MODW1A MWAVE- MOUNTED OVER RANGE/WO
Magic Chef MODW1V MWAVE- MOUNTED OVER RANGE/WO
Amana MP1.A COMMERCIAL MICROWAVES
Amana MP1.B COMMERCIAL MICROWAVES
Amana MPD218-02 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire MPF200PBDA Frg(v2) / Gas Range
Frigidaire MPF200PBWA Frg(v1) / Gas Range
Frigidaire MPF240GSA GAS RANGE
Frigidaire MPF300BPDA Gib(v9) / Gas Range
Frigidaire MPF300PBDA Frg(v1) / Gas Range
Frigidaire MPF300PBDB Wwh(v1) / Gas Range
Frigidaire MPF300PBDC Frg(v1) / Gas Range
Frigidaire MPF300PBDD Frg(v1) / Gas Range
Frigidaire MPF300PBDE Frg(v1) / Gas Range
Frigidaire MPF300PBDF Frg(v1) / Gas Range
Frigidaire MPF300PBWA Frg(v2) / Gas Range
Frigidaire MPF300PBWB Wwh(v2) / Gas Range
Frigidaire MPF300PBWC Frg(v2) / Gas Range
Frigidaire MPF300PBWD Frg(v2) / Gas Range
Frigidaire MPF300PBWE Frg(v2) / Gas Range
Frigidaire MPF300PBWF Frg(v2) / Gas Range
Frigidaire MPF300PXWA Frg(v0) / Gas Range
Frigidaire MPF300PXWB Frg(v3) / Gas Range
Frigidaire MPF300PXWC Frg(v0) / Gas Range
Frigidaire MPF300PXWG Universal/gas Range
Frigidaire MPF300PXWH Universal/gas Range
Frigidaire MPF300PXWJ Universal/gas Range
Frigidaire MPF303PGDA Frg(v3) / Gas Range
Frigidaire MPF303PGDD Frg(v5) / Gas Range
Frigidaire MPF303PGDF Universal/gas Range
Frigidaire MPF303PGDG Universal/gas Range
Frigidaire MPF303PGDH Universal/gas Range
Frigidaire MPF303PGWA Frg(v4) / Gas Range
Frigidaire MPF303PGWC Frg(v6) / Gas Range
Frigidaire MPF303PGWD Frg(v7) / Gas Range
Frigidaire MPF303PGWF Universal/gas Range
Frigidaire MPF303PGWG Universal/gas Range
Frigidaire MPF303PGWH Universal/gas Range
Frigidaire MPF311PCDA Tap(v1) / Gas Range
Frigidaire MPF311PCWA Tap(v2) / Gas Range
Frigidaire MPF311PCWB Frg(v0) / Gas Range
Frigidaire MPF311PCWC Frg(v1) / Gas Range
Frigidaire MPF311PCWD Frg(v0) / Gas Range
Frigidaire MPF311PGWA Frg(v3) / Gas Range
Frigidaire MPF311PGWC Frg(v3) / Gas Range
Frigidaire MPF311PGWD Frg(v3) / Gas Range
Frigidaire MPF311PGWE Universal/gas Range
Frigidaire MPF311SBDA Frg(v3) / Gas Range
Frigidaire MPF311SBDB Frg(v1) / Gas Range
Frigidaire MPF311SBDC Frg(v2) / Gas Range
Frigidaire MPF311SBDD Frg(v1) / Gas Range
Frigidaire MPF311SBWA Frg(v4) / Gas Range
Frigidaire MPF311SBWB Frg(v2) / Gas Range
Frigidaire MPF311SBWC Frg(v3) / Gas Range
Frigidaire MPF311SBWD Frg(v2) / Gas Range
Frigidaire MPF311SGDA Frg(v4) / Gas Range
Frigidaire MPF311SGDC Frg(v4) / Gas Range
Frigidaire MPF311SGDD Frg(v4) / Gas Range
Frigidaire MPF311SGDE Universal/gas Range
Frigidaire MPF311SGWA Frg(v5) / Gas Range
Frigidaire MPF311SGWC Frg(v5) / Gas Range
Frigidaire MPF311SGWD Frg(v5) / Gas Range
Frigidaire MPF311SGWE Universal/gas Range
Frigidaire MPF500PBDA Frg(v4) / Gas Range
Frigidaire MPF500PBDB Frg(v1) / Gas Range
Frigidaire MPF500PBWA Frg(v3) / Gas Range
Frigidaire MPF500PBWB Frg(v2) / Gas Range
Amana MPP227 MWAVE- CNTRTP / STAND ALONE
Amana MPP228 MWAVE- CNTRTP / STAND ALONE
Amana MPP228100L MWAVE - FAMILY SIZE (60 HZ)
Amana MPR215 MWAVE- CNTRTP / STAND ALONE
Amana MPR21510 MWAVE- MOUNTED OVER RANGE/WO
Amana MPR217 MWAVE- CNTRTP / STAND ALONE
Amana MPR219 MWAVE- CNTRTP / STAND ALONE
Amana MPS218-10 RANGE- S/C S/I DDRAFT GAS
Amana MPS218-10 MWAVE- CNTRTP / STAND ALONE
Amana MPS219-10 RANGE- S/C S/I DDRAFT GAS
Amana MPS219-10 MWAVE- CNTRTP / STAND ALONE
Amana MPS225-10 MWAVE - FAMILY SIZE (60 HZ)
Amana MPS22510 MWAVE - FAMILY SIZE (60 HZ)
Amana MPS229-10 MWAVE - FAMILY SIZE (60 HZ)
Amana MPS22910 MWAVE - FAMILY SIZE (60 HZ)
Maytag MQC1557AEW FREEZER- VERTICAL
Maytag MQC1557BEW FREEZER- CHEST
Maytag MQC2257AEW FREEZER- CHEST
Maytag MQC2257BEW FREEZER- CHEST
Maytag MQU1554AEW FREEZER- VERTICAL
Maytag MQU1556AEW FREEZER- VERTICAL
Maytag MQU1654BEW FREEZER- VERTICAL
Maytag MQU1656BEW FREEZER- VERTICAL
Maytag MQU2056ARW FREEZER- VERTICAL
Maytag MQU2056BRW FREEZER- VERTICAL
Maytag MQU2056BRW03 VERTICAL FREEZER
Maytag MQU2057AEW FREEZER- VERTICAL
Maytag MQU2057BEW FREEZER- VERTICAL
Amana MR-1 RANGE- S/C S/I DDRAFT GAS
Amana MR-1W MWAVE - FAMILY SIZE (60 HZ)
Amana MR-2 RANGE- S/C S/I DDRAFT GAS
Amana MR-3 MWAVE - FAMILY SIZE (60 HZ)
 MR1031CWC MWAVE- CNTRTP / STAND ALONE
 MR1031UWC MWAVE- CNTRTP / STAND ALONE
 MR1031WB MWAVE- CNTRTP / STAND ALONE
 MR1032BB MWAVE- CNTRTP / STAND ALONE
 MR1032CBC MWAVE- CNTRTP / STAND ALONE
 MR1032UBC MWAVE- CNTRTP / STAND ALONE
 MR1033SB MWAVE- CNTRTP / STAND ALONE
 MR1034CBD MWAVE- CNTRTP / STAND ALONE
 MR1034CWD MWAVE- CNTRTP / STAND ALONE
 MR1034UBD MWAVE- CNTRTP / STAND ALONE
 MR1034UWD MWAVE- CNTRTP / STAND ALONE
 MR1351WB MWAVE- CNTRTP / STAND ALONE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F1 failure code in self clean mode only scruffydog Oven Repair (including Ranges and Cooktops) 12 05-07-2012 02:48 PM
Stand Alone Ice Maker paradise12870 Refrigerator & Freezer Repair 1 02-09-2011 03:31 PM
Stand alone ice maker BKTYLTX Refrigerator & Freezer Repair 2 04-15-2010 07:01 AM
Stand alone Ice Maker jenkinspr Refrigerator & Freezer Repair 0 02-28-2009 08:50 AM
Stand Alone Ice Maker Tim Beeker Refrigerator & Freezer Repair 0 11-24-2008 05:24 PM
