Discuss
Kitchenaid Superba Ice Dispensor
 in
Refrigerator & Freezer Repair
The ice dispenser on the freezer door will not run. The water dispenser works fine. I had the refriderator unplugged
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kitchenaid Superba Ice Dispensor
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-27-2007, 01:07 PM
Adamk523 Adamk523 is offline
Junior Member
Adamk523 is on a distinguished road
Default Kitchenaid Superba Ice Dispensor
Brand: Kitchen Aid   Age: 5 - 10 years
The ice dispenser on the freezer door will not run. The water dispenser works fine. I had the refriderator unplugged for an hour. Plugged it back in, and the ice dispenser no longer runs. I can't figure out how to get access to the motor. There are 2 screws where the motor is, but removing them does not allow you to remove it. It seems like ice melted and froze the motor. Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-27-2007, 02:33 PM
fixxit fixxit is online now
Senior Expert
APP Volunteer
fixxit is on a distinguished road
Default
your model # would be helpful. would be in the refer section usualy around top shelf right hand or left hand side, though i have seen it across the top
  #3 (permalink)
Old 10-27-2007, 05:49 PM
jimb jimb is offline
Junior Member
jimb is on a distinguished road
Default Me Too
I also have a kitchenaid but with a slightly different symptom: empty tray (no water dispensed). But I think that there is a common cause. The motorized mechanism that creates the fill-eject cycle is not stoppied in the correct location - In my case the nylon ejecting finger unit is stopped in the straight down position.
I have hot-wired the tan colored valve so I know that the valve works and there are no clogs in the water line.
I'm assuming that somewhere there is a simple timer/controller. But before it hunt that down - can I rule out the mechanism? Will a jammed mechanism keep the water from dispensing? Where's the best location to get to the motor wire harness - I'd like to hot-wire the motor to check for the jam.
  #4 (permalink)
Old 05-04-2008, 10:57 PM
barryiseager barryiseager is offline
Junior Member
barryiseager is on a distinguished road
Default Kitchenaid Ice maker fix for the superba
Solution #2
posted on May 05, 2008
Use a cup of water and just fill the ice cube maker with enough water for the first batch and the sensor will then begin making ice again.
My ice cube maker stopped working after I changed the filter. After reading countless posts about wiring and defrosting and using a blowdryer into the fill line I emptied my freezer and fridge, then unplugged it. I got no results after two days. I finally just put some water in the ice cube maker (the metal ice cube tray below the white plastic fingers that forms the cubes) plugged it back in and closed the door for a few hours and it worked. I wonder if I needed to defrost the unit at all. It was working before I changed the filter, then the filter was full and stopped water from flowing (or decreased the flow dramatically anyway).
Good Luck
Barry Eager
  #5 (permalink)
Old 05-15-2008, 12:52 PM
carlso2 carlso2 is offline
Junior Member
carlso2 is on a distinguished road
Default
I have one of these Superba side-by-sides with yet another problem. I am finding a frozen puddle of water on the floor of the freezer close to the door. When I shut off the ice maker, the puddle doesn't form again. So there must be a water leak, but it is simply not evident where it is coming from.
The model # is KSRS271HSS02 Mfg- 10/00
Does anyone have any experience with this?
Thanks.
  #6 (permalink)
Old 06-02-2008, 05:26 PM
Erv Erv is offline
Junior Member
Erv is on a distinguished road
Default
i am going to try to hand fill the ice maker first and see if this works. then tomorrow i'm going to go and get a new filter and see if that is the problem. I have no water going to ice maker but water goes to dispenser.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ice maker dispensor hemihead Refrigerator & Freezer Repair 0 10-09-2007 03:53 PM
soap dispensor problem dsoakes Dishwasher Repair 1 10-03-2007 08:38 PM
kitchenaid superba refrigerator claire sullivan Refrigerator & Freezer Repair 0 09-30-2007 05:53 AM
kitchenaid icemaker matthew Refrigerator & Freezer Repair 1 09-02-2007 10:40 AM
kichenaid superba soap dispenser ralph Dishwasher Repair 1 08-31-2007 03:47 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
