I just noticed that my Whirlpool Gold fridge w/ bottom freezer keeps running and won't shut off. The temp setting in the freezer compartment is only set on 2, and when I turned it down to see if I could get the thermostat to shut off, it wouldn't. It would only turn off when I positioned the dial all the way back to zero, and yet I still didn't hear the little "click" the thermostat normally makes. I'm guessing it needs a new thermostat, but don't know where that is located. I cannot find a service manual for this appliance although I searched 3 different online appliance manual providers, but only found a parts catalog available. Does this sound like the actual problem, and is the thermostat easy to get to in order to replace? Where is it located?
Thanks in advance for any advice on this.
Chuck :confused:
