Discuss
Kenmore Fridge freezing food even at lowest setting
 in
Refrigerator & Freezer Repair
We have a side by side Kenmore fridge/freezer. The freezer is fine. The fridge freezes food even at the lowest
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Fridge freezing food even at lowest setting
  #1 (permalink)
Old 03-29-2011, 05:18 AM
Junior Member
Atoussa is on a distinguished road
Default Kenmore Fridge freezing food even at lowest setting
Model Number: 253.52649301   Brand: Kenmore   Age: 5 - 10 years
We have a side by side Kenmore fridge/freezer. The freezer is fine. The fridge freezes food even at the lowest setting. We cleaned the vents and anywhere in the back where there may have been dust. Now the water doesn't dispense either, and the filter leaks out water which turns into ice fairly instantly and as a result pops the filter out because of the water/ice accumulation. The fridge is approx 9 years old. Do we need to replace the thermostat or the entire fridge? I know the filter needs replacing.
Related Models
Frigidaire 2530A GAS RANGE
Frigidaire 2530B GAS RANGE
Frigidaire 2530C GAS RANGE
Frigidaire 2530D GAS RANGE
Frigidaire 2530E GAS RANGE
Kenmore 25310301000 CHEST FREEZER
Kenmore 25310301001 CHEST FREEZER
Kenmore 25310311000 CHEST FREEZER
Kenmore 25310311001 CHEST FREEZER
Kenmore 25310311002 FREEZER
Kenmore 25310911990 FREEZER
Kenmore 25310911991 CHEST FREEZER
Kenmore 25310911992 CHEST FREEZER
Kenmore 25311301100 FREEZER
Kenmore 25311301101 FREEZER
Kenmore 25311311100 CHEST FREEZER
Kenmore 25311312100 FREEZER
Kenmore 25311312101 FREEZER
Kenmore 25311312102 SEARS/FREEZER
Kenmore 25311321100 CHEST FREEZER
Kenmore 25311321101 FREEZER
Kenmore 25311351100 FREEZER
Kenmore 25311351101 CHEST FREEZER
Kenmore 25311351102 FREEZER
Kenmore 25311511100 CHEST FREEZER
Kenmore 25311511101 FREEZER
Kenmore 25311521100 FREEZER
Kenmore 25311521102 CHEST FREEZER
Kenmore 25311521103 FREEZER
Kenmore 25311531100 FREEZER
Kenmore 25311531101 FREEZER
Kenmore 25311531102 FREEZER
Kenmore 25311531103 FREEZER
Kenmore 25311541100 CHEST FREEZER
Kenmore 25311541102 FREEZER
Kenmore 25311711100 FREEZER
Kenmore 25311711101 CHEST FREEZER
Kenmore 25311711102 FREEZER
Kenmore 25311821100 FREEZER
Kenmore 25311821101 FREEZER
Kenmore 25311911100 FREEZER
Kenmore 25311911101 FREEZER
Kenmore 25312021100 FREEZER
Kenmore 25312021101 FREEZER
Kenmore 25312021102 FREEZER
Kenmore 25312541100 FREEZER
Kenmore 25312541102 SEARS/FREEZER
Kenmore 25312551100 FREEZER
Kenmore 25313009100 FREEZER
Kenmore 25313051100 FREEZER
Kenmore 25313051101 FREEZER
Kenmore 25313051102 FREEZER
Kenmore 25313051103 FREEZER
Kenmore 25313312101 FREEZER
Kenmore 25313351100 FREEZER
Kenmore 25313500100 FREEZER
Kenmore 25313500101 FREEZER
Kenmore 25313500102 FREEZER
Kenmore 25313500103 FREEZER
Kenmore 25313511100 CHEST FREEZER
Kenmore 25313511101 FREEZER
Kenmore 25313511102 FREEZER
Kenmore 25313541101 FREEZER
Kenmore 25313541102 FREEZER
Kenmore 25313551100 FREEZER
Kenmore 25313551101 FREEZER
Kenmore 25313711100 FREEZER
Kenmore 25313711101 FREEZER
Kenmore 25313711102 FREEZER
Kenmore 25313712100 FREEZER
Kenmore 25313712101 FREEZER
Kenmore 25313911100 FREEZER
Kenmore 25313911101 FREEZER
Kenmore 25313911102 FREEZER
Kenmore 25314092101 FREEZER
Kenmore 25314092102 FREEZER
Kenmore 25314092103 FREEZER
Kenmore 25314342100 FREEZER
Kenmore 25314342101 FREEZER
Kenmore 25314342102 FREEZER
Kenmore 25314352100 FREEZER
Kenmore 25314352101 FREEZER
Kenmore 25314352102 FREEZER
Kenmore 25314502100 FREEZER
Kenmore 25314502101 FREEZER
Kenmore 25314502102 FREEZER
Kenmore 25314502103 FREEZER
Kenmore 25314502104 FREEZER
Kenmore 25314502105 FREEZER
Kenmore 25314512100 FREEZER
Kenmore 25314512101 FREEZER
Kenmore 25314512102 FREEZER
Kenmore 25314512103 FREEZER
Kenmore 25314512104 FREEZER
Kenmore 25314542100 FREEZER
Kenmore 25314542101 FREEZER
Kenmore 25314542102 FREEZER
Kenmore 25314542103 FREEZER
Kenmore 25314542104 FREEZER
Kenmore 25314542105 FREEZER
Kenmore 25314552100 FREEZER
Kenmore 25314552101 FREEZER
Kenmore 25314552102 FREEZER
Kenmore 25314582100 FREEZER
Kenmore 25314592100 FREEZER
Kenmore 25314592101 FREEZER
Kenmore 25314592102 FREEZER
Kenmore 25314702100 FREEZER
Kenmore 25314702101 FREEZER
Kenmore 25314702102 FREEZER
Kenmore 25314702103 FREEZER
Kenmore 25314702104 FREEZER
Kenmore 25314712100 FREEZER
Kenmore 25314712101 FREEZER
Kenmore 25314712102 FREEZER
Kenmore 25314712103 FREEZER
Kenmore 25314772100 FREEZER
Kenmore 25314772101 FREEZER
Kenmore 25314772102 FREEZER
Kenmore 25314772103 FREEZER
  #2 (permalink)
Old 03-29-2011, 10:04 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Atoussa,
First thing you need to check is the auto damper. Located on the left side back wall of the fresh food compartment. if the damper motor has failed or the door has failed and is stuck open, you'll have too much cold air from the freezer, and the f/f compartment will freeze.
Part number: AP5176342
That is most likely the reason for all the complaints.
Here is the part number for your filter as well, you mentioned you needed one.
Part number: AP2538969
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 01-08-2012, 02:50 PM
Junior Member
julesw is on a distinguished road
Default Re: Kenmore fridge freezing food even at lowest setting
My Kenmore does the same thing and recently it's getting much worse. It used to just happen with one drawer now anything on most of the lower shelves freezes even though I'm on the lowest settings.
My model is 9957953. Any suggestions?
Thanks so much.
  #4 (permalink)
Old 01-10-2012, 06:18 AM
Senior Expert
Default
Thanks so much.
Jules,
The checks are the same on most refrigerators, is the freezer temperature too low ? You want an air temperature of 5 to 7 dgrs. F. Check and make sure there's nothing hanging over the sides of the shelves, or against the back wall, re directing the air flow. Check the top shelf and make sure, there nothing "tall" or bulky, blacking the damper assembly. If all checks OK, then check or replace the damper assembly.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Fridge Freezing Food In Fresh Food Section, Veg And Fuit Drawers CGIM5804 Refrigerator & Freezer Repair 1 04-26-2017 10:41 AM
GE refridgerator Freezing food in Fridge and freezing water line niloa Refrigerator & Freezer Repair 1 02-03-2011 08:36 PM
refridgerator freezing food and waterline on warmest setting adlook Refrigerator & Freezer Repair 0 12-16-2009 06:25 AM
food in fridge freezing even on lowest setting sustanetti Refrigerator & Freezer Repair 4 08-22-2009 03:35 PM
inside of fridge temprature to cold on lowest setting. LSobo Refrigerator & Freezer Repair 1 08-28-2008 04:09 PM
