Discuss
Replace Ice dispenser gasket
 in
Refrigerator & Freezer Repair
How do you remove the Ice dispenser from the freezer door to replace the gasket?
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Replace Ice dispenser gasket
  #1 (permalink)
Old 10-26-2007, 03:00 PM
jcoreno jcoreno is offline
Junior Member
jcoreno is on a distinguished road
Default Replace Ice dispenser gasket
Model Number: ED22GWXWN10   Brand: Whirlpool   Age: 5 - 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-26-2007, 03:19 PM
fixxit fixxit is offline
Senior Expert
APP Volunteer
fixxit is on a distinguished road
Default
are trying to replace the dispenser door flap seal. if so you can simply open the freezer door (this will disable the auger) open the door flap and pull the seal off of the flap. if your talking about another seal you will have to clairify.
  #3 (permalink)
Old 10-26-2007, 03:21 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi jcoreno
- Here is the ice and water dispenser break down diagram for the Whirlpool refrigerator Model ED22GWXWN10
The front dispenser cover can be removed by inserting a screwdriver blade into the two slots on the bottom side of the cover. By gently turning the blade, the cover will snap free at the bottom and can be slid upward to be removed.
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Problem with door gasket installation bayleyspop Refrigerator & Freezer Repair 7 03-21-2008 01:52 PM
Door gasket gla80 Refrigerator & Freezer Repair 0 10-18-2007 05:58 AM
Freezer gasket problem Timothy Wagner\ Refrigerator & Freezer Repair 0 10-08-2007 11:14 AM
Where does this gasket go? (seal replacement) g3_ultra Washer Repair 0 09-01-2007 11:09 AM
gasket refrigerator replace tmjm04 Refrigerator & Freezer Repair 0 08-21-2007 06:10 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
