Discuss
ice in bottom of freezer
 in
Refrigerator & Freezer Repair
after numerous times of removing ice in bottom of freezer, we tried defrosting all coils under back panel, also the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ice in bottom of freezer
  #1 (permalink)
Old 10-26-2007, 09:37 AM
Doug Lawheed Doug Lawheed is offline
Junior Member
Doug Lawheed is on a distinguished road
Default ice in bottom of freezer
Model Number: 25359489990   Brand: Kenmore   Age: 5 - 10 years
after numerous times of removing ice in bottom of freezer, we tried defrosting all coils under back panel, also the drain hole. two days later we have the same sitiuation. the temp is set @ #2.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-26-2007, 11:17 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Doug
How did you defrost it?
I would recommend remove all shelves and the back panel. Using a hair dryer, defrost all ice under the evaporator coils and the drain hole, then using a cup with very hot water make sure water goes through the drain.
If it does not, remove the cover on the back of the fridge, locate the end of the drain hose and make sure it is not clogged.
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 10-27-2007, 10:17 AM
Junior Member
Dear Gene,
Thank you for the information. We defrosted with dryer again, and this time took the back off and cleared the drain hose. Checked the defrost heater and it was 1.8 ohms, and defrost thermostat was normally open, but schematic showed it normally closed, which I believe to be incorrect.
I think our problem is solved, but I should know in a day or two.
Thank you again for your help.
Doug
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bottom freezer works top fridge barely cool mickey Refrigerator & Freezer Repair 2 10-15-2007 05:20 PM
ice build up in the bottom of the freezer lauder Refrigerator & Freezer Repair 1 08-22-2007 08:53 PM
frost forming in bottom freezer compartment Betty Refrigerator & Freezer Repair 0 08-22-2007 07:48 AM
Amana bottom freezer refrigerator MAL Refrigerator & Freezer Repair 1 08-18-2007 06:47 PM
Water accumulating and freezing in bottom of freezer Bigz Refrigerator & Freezer Repair 0 07-31-2007 08:45 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
