Discuss
Freezer and Fridge not cooling
 in
Refrigerator & Freezer Repair
Freezer is cooling but not freezing the water in the icemaker and food is starting to soften in the freezer.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer and Fridge not cooling
  #1 (permalink)
Old 03-25-2011, 09:34 AM
EdP EdP is offline
Junior Member
EdP is on a distinguished road
Default Freezer and Fridge not cooling
Model Number: KSRS25IHSS02   Brand: Kitchen Aid   Age: More than 10 years
Freezer is cooling but not freezing the water in the icemaker and food is starting to soften in the freezer. The Overload/Relay Switch attached to the compressor will click, the compressor tries to start for 7 seconds (humming noise from the compresor), another click from the (Overload/Relay Switch), compressor stops humming. This process cycles about every minute 35 seconds. Question: will replacing the Overload/Relay Switch fix my problem? The Overload/Relay Switch has three female that plugs into the three male compressor attached pins.
Is Part No. AP3083556 the right Overload/Relay Switch for my fridge? Do I need to replace the capacitor also that is wired to the Overload/Relay Switch?
Thank you
Ads By Google
Related Models
Whirlpool KSRS25IHSS02
Whirlpool KSRS25IHWH00
Whirlpool KSRS25IHWH02
Whirlpool KSRS25IKBL00
Whirlpool KSRS25IKBL01
Whirlpool KSRS25IKBL03 Refrigerator
Whirlpool KSRS25IKBT00
Whirlpool KSRS25IKBT01
Whirlpool KSRS25IKBT03 Refrigerator
Whirlpool KSRS25IKBU00
Whirlpool KSRS25IKBU01
Whirlpool KSRS25IKBU03 Refrigerator
Whirlpool KSRS25IKSS00
Whirlpool KSRS25IKSS01
Whirlpool KSRS25IKSS03 Refrigerator
Whirlpool KSRS25IKWH00
Whirlpool KSRS25IKWH01
Whirlpool KSRS25IKWH03 Refrigerator
Whirlpool KSRS25ILBL00 Refrigerator
Whirlpool KSRS25ILBL01 Refrigerator
Whirlpool KSRS25ILBL02 Refrigerator
Whirlpool KSRS25ILBL03 Refrigerator
Whirlpool KSRS25ILBL13 Refrigerator
Whirlpool KSRS25ILBT00 Refrigerator
Whirlpool KSRS25ILBT01 Refrigerator
Whirlpool KSRS25ILBT02 Refrigerator
Whirlpool KSRS25ILBT03 Refrigerator
Whirlpool KSRS25ILBT13 Refrigerator
Whirlpool KSRS25ILBU00 Refrigerator
Whirlpool KSRS25ILBU01 Refrigerator
Whirlpool KSRS25ILBU02 Refrigerator
Whirlpool KSRS25ILSS00 Refrigerator
Whirlpool KSRS25ILSS01 Refrigerator
Whirlpool KSRS25ILSS02 Refrigerator
Whirlpool KSRS25ILSS03 Refrigerator
Whirlpool KSRS25ILSS13 Refrigerator
Whirlpool KSRS25ILWH00 Refrigerator
Whirlpool KSRS25ILWH01 Refrigerator
Whirlpool KSRS25ILWH02 Refrigerator
Whirlpool KSRS25ILWH03 Refrigerator
Whirlpool KSRS25ILWH13 Refrigerator
Whirlpool KSRS25KGAL00
Whirlpool KSRS25KGBL00
Whirlpool KSRS25KGBL01
Whirlpool KSRS25KGBL02
Whirlpool KSRS25KGBL03
Whirlpool KSRS25KGBT01
Whirlpool KSRS25KGBT02
Whirlpool KSRS25KGBT03
Whirlpool KSRS25KGWH00
Whirlpool KSRS25KGWH01
Whirlpool KSRS25KGWH02
Whirlpool KSRS25KGWH03
Whirlpool KSRS25PNBL00 Refrigerator
Whirlpool KSRS25PNBT00 Refrigerator
Whirlpool KSRS25PNLK00 Refrigerator
Whirlpool KSRS25PNSS00 Refrigerator
Whirlpool KSRS25PNWH00 Refrigerator
Whirlpool KSRS25QAAL00
Whirlpool KSRS25QAAL01
Whirlpool KSRS25QAAL02
Whirlpool KSRS25QAAL10
Whirlpool KSRS25QAAL11
Whirlpool KSRS25QAWH00
Whirlpool KSRS25QAWH01
Whirlpool KSRS25QAWH02
Whirlpool KSRS25QAWH10
Whirlpool KSRS25QAWH11
Whirlpool KSRS25QDAL00
Whirlpool KSRS25QDAL01
Whirlpool KSRS25QDAL03
Whirlpool KSRS25QDWH00
Whirlpool KSRS25QDWH01
Whirlpool KSRS25QDWH03
Whirlpool KSRS25QFAL00
Whirlpool KSRS25QFBL00
Whirlpool KSRS25QFWH00
Whirlpool KSRS25QGAL00
Whirlpool KSRS25QGAL01
Whirlpool KSRS25QGAL02
Whirlpool KSRS25QGAL03
Whirlpool KSRS25QGAL04
Whirlpool KSRS25QGAL05
Whirlpool KSRS25QGBL00
Whirlpool KSRS25QGBL01
Whirlpool KSRS25QGBL02
Whirlpool KSRS25QGBL03
Whirlpool KSRS25QGBL04
Whirlpool KSRS25QGBL05
Whirlpool KSRS25QGBT02
Whirlpool KSRS25QGBT03
Whirlpool KSRS25QGBT04
Whirlpool KSRS25QGBT05
Whirlpool KSRS25QGWH00
Whirlpool KSRS25QGWH01
Whirlpool KSRS25QGWH02
Whirlpool KSRS25QGWH03
Whirlpool KSRS25QGWH04
Whirlpool KSRS25QGWH05
Whirlpool KSRS25QWAL11
Whirlpool KSRS25QWAL13
Whirlpool KSRS25QWWH11
Whirlpool KSRS25QWWH13
Whirlpool KSRS25QXAL00
Whirlpool KSRS25QXAL10
Whirlpool KSRS25QXAL11
Whirlpool KSRS25QXWH00
Whirlpool KSRS25QXWH10
Whirlpool KSRS25QXWH11
Whirlpool KSRS25RSBL00 Refrigerator
Whirlpool KSRS25RSBL01 Refrigerator
Whirlpool KSRS25RSBT00 Refrigerator
Whirlpool KSRS25RSBT01 Refrigerator
Whirlpool KSRS25RSMK00 Refrigerator
Whirlpool KSRS25RSMK01 Refrigerator
Whirlpool KSRS25RSMS00 Refrigerator
Whirlpool KSRS25RSMS01 Refrigerator
Whirlpool KSRS25RSWH00 Refrigerator
Whirlpool KSRS25RSWH01 Refrigerator
Whirlpool KSRS25RVBL00 Refrigerator
  #2 (permalink)
Old 03-25-2011, 12:28 PM
Jeff / APP Team's Avatar
Senior Expert
Jeff / APP Team is on a distinguished road
Default
Hello EdP. You can test the compressor windings and see if it is good. The run windings will read 1-5 ohms, and the start will read 3-11 ohms. Also check from the terminals to ground and make sure the compressor is not grounding out. If the compressor checks good, then the overload should fix your problem. Hope this helps.
Part number: AP3873993
Unit replacement parts for WHIRLPOOL KSRS25IHSS02 | AppliancePartsPros.com
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Jeff K. / APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-28-2011, 11:54 AM
EdP EdP is offline
Junior Member
Default
Quote:
Originally Posted by Jeff / APP Team View Post
Hello EdP. You can test the compressor windings and see if it is good. The run windings will read 1-5 ohms, and the start will read 3-11 ohms. If the compressor checks good, then the overload should fix your problem. Hope this helps.
Hello Jeff,
I checked the Start/Run/Common and they check out good. I have uploaded pictures of my relay/overload and I do use a separate capacitor. Looking at Part Number: AP 3873993 and only showing one picture, though the compatibiltiy list shows this is the right part for my KSRS25IHSS02 KitchenAid Fridge, it does not look the same as my relay/overload. The link post that was sent along with your reply suggested as an alternative Part No. AP407740 that does look similar on the side that connects to the compressor but the other side I'm not sure. But, my Fridge is not on the compatibility list for this Part No. AP407740. On my Relay/Overload there are a blue and a white wires from the capacitor that attach to the start and run terminals. The terminal that has the white wire, there is another white wire going to the compressor and the common terminal has a red wire going to the compressor motor. Which Part No. should I purchase? AP3873993 or AP407740.
Thank you.
  #4 (permalink)
Old 03-28-2011, 12:22 PM
Senior Expert
Default
You will need to purchase the one that your model number calls for. This is a redesigned kit and will work on your model. Hope this helps. Part number: AP3873993
__________________
Jeff K. / APP TEAM
  #5 (permalink)
Old 03-28-2011, 12:26 PM
EdP EdP is offline
Junior Member
Default
Will do right now.
Jeff, thanks for your help.
Ed
  #6 (permalink)
Old 03-28-2011, 12:29 PM
Senior Expert
Default
Your welcome!! Let us know how it turns out!
__________________
Jeff K. / APP TEAM
  #7 (permalink)
Old 03-31-2011, 10:01 AM
EdP EdP is offline
Junior Member
Default
Jeff,
Installed new overload/relay yesterday and the fridge has been running for a day now without the constant clicking noise of the bad overload/relay. The freezer and fridge are freezing and cooling perfectly. This problem has been fixed. Thank you for your correct and precise help on my problem.
Ed
  #8 (permalink)
Old 03-31-2011, 11:09 AM
Senior Expert
Default
Your welcome! Glad we could help!!!
__________________
Jeff K. / APP TEAM
  #9 (permalink)
Old 05-16-2011, 11:15 AM
Junior Member
tharpappliances is on a distinguished road
Default Similar part for model # 10652582201
Hello,
I was wondering if there exists a similar item for model 10652582201, or if I should just use a hard start kit (AP4503017)?
I am having the same symptoms as stated previously.
Thank You,
Kevin
  #10 (permalink)
Old 05-16-2011, 12:42 PM
Senior Expert
Default
Hello tharpappliances. Here is the relay overload kit for the model number you provided. Hope this helps.
Part number: AP3885081
__________________
Jeff K. / APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Fridge/Freezer Not Cooling Freezer Properly woody1397 Refrigerator & Freezer Repair 1 02-02-2011 06:56 PM
started up s/s fridge. freezer working fine, but fridge is not cooling dkusko Refrigerator & Freezer Repair 0 09-05-2010 09:40 AM
Replacing Fridge Fan, freezer works, fridge not cooling dlake1 Refrigerator & Freezer Repair 4 07-22-2010 06:01 AM
Fridge Not Cooling And Freezer Feels Like Fridge Should ETHANSMOMMA Refrigerator & Freezer Repair 1 06-09-2010 10:39 PM
Fridge and Freezer not cooling Richard Beasley Refrigerator & Freezer Repair 3 06-05-2009 02:23 PM
