Discuss
Freezer and Fridge not cooling
 in
Refrigerator & Freezer Repair
I am having this issue which sounds the similar as the orginal post. My frigidaire refrigerator (FRS26W2AWE) starting making a
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer and Fridge not cooling
  #11 (permalink)
Old 12-23-2011, 08:57 AM
Junior Member
sdpalmer8 is on a distinguished road
Default
My frigidaire refrigerator (FRS26W2AWE) starting making a humming sound after a click from around the compressor. Then after about 10-20 seconds it would stop after another click. It seemed to be working fine until last night when everything quit cooling and the freezer thawed out. In looking at it this morning, it trys blowing but with the final click it stops. My question is compressor or the start up relay?
Any Help??
Ads By Google
  #12 (permalink)
Old 12-23-2011, 08:59 AM
Jeff / APP Team's Avatar
Senior Expert
Jeff / APP Team is on a distinguished road
Default
Hello Do the test above. It sounds like the starter is bad on the unit. Hope this helps.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Jeff K. / APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #13 (permalink)
Old 12-23-2011, 09:01 AM
Junior Member
Default
How do I check the compressor? Also, what starter kit for my unit?
  #14 (permalink)
Old 12-27-2011, 08:04 AM
Senior Expert
Default
Hello. The test for the compressor is listed at the top of this post. As for the correct starter, based on the model number you provided, below is the correct start relay. Hope this helps.
Part number: AP4367355
__________________
Jeff K. / APP TEAM
  #15 (permalink)
Old 01-13-2012, 04:48 AM
WCD WCD is offline
Junior Member
WCD is on a distinguished road
Default
Quote:
Originally Posted by EdP View Post
The Overload/Relay Switch attached to the compressor will click, the compressor tries to start for 7 seconds (humming noise from the compresor), another click from the (Overload/Relay Switch), compressor stops humming. This process cycles about every minute 35 seconds. Question: will replacing the Overload/Relay Switch fix my problem? The Overload/Relay Switch has three female that plugs into the three male compressor attached pins.
I have the exact same problem with a Frigidaire Side by side. I ordered and replaced the Starter based on this discussion. The unit worked all evening, but this morning the click and buzz is back. Obviously not the Start/Overload switch on the compressor.
Compressor output temp is hot but not extreme, and the fridge and freezer sections maintain good temperatures. Plenty of voltage going to the refrigerator (124 Volts).
Would changing the CAPACITOR help the compressor to start (and stop the Start/Overload from buzzing), or does this sound like a Compressor problem?
Thanks in advance!
  #16 (permalink)
Old 01-13-2012, 04:53 AM
Senior Expert
Default
Hello WCD. It sounds like you may have a bad compressor on this one. If you replaced the starter and the unit worked, then as the pressure built, on restart, clicking returns, then the compressor is bad on the unit. Hope this helps.
__________________
Jeff K. / APP TEAM
  #17 (permalink)
Old 06-13-2012, 05:31 PM
Junior Member
MBrooks is on a distinguished road
Question Problem same as original poster with exception
Hello, I have an MTB1950GRW with the same problem as the original poster. Mine quit cooling and freezing a couple of days ago, the light and fans all worked and there was a clicking sound coming from compressor area, however today when I plugged it back in I had nothing but a light, no fans and no clicking noise. Please help
  #18 (permalink)
Old 06-15-2012, 07:48 AM
Senior Expert
Default
Hello. The unit may be in the defrost cycle. Try turning the timer and see if the unit then tries to start. If so, you will need to do the above test and determine if the compressor is bad or the start relay.
Part number: AP4084056
__________________
Jeff K. / APP TEAM
  #19 (permalink)
Old 06-22-2012, 02:18 PM
Junior Member
Default
Thank you so much!! While waiting for an answer I went ahead and replaced both the start device and the run capacitor and still the unit would not start, I was ready to decide it was a bad compressor when I remembered posting here, so I came back and found your reply to my posting and yes when I turned the defrost timer the unit started right up! Thank you again, you were a great help.
  #20 (permalink)
Old 06-26-2012, 04:52 AM
Senior Expert
Default
Great News!! Glad we could help!!
__________________
Jeff K. / APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Fridge/Freezer Not Cooling Freezer Properly woody1397 Refrigerator & Freezer Repair 1 02-02-2011 06:56 PM
started up s/s fridge. freezer working fine, but fridge is not cooling dkusko Refrigerator & Freezer Repair 0 09-05-2010 09:40 AM
Replacing Fridge Fan, freezer works, fridge not cooling dlake1 Refrigerator & Freezer Repair 4 07-22-2010 06:01 AM
Fridge Not Cooling And Freezer Feels Like Fridge Should ETHANSMOMMA Refrigerator & Freezer Repair 1 06-09-2010 10:39 PM
Fridge and Freezer not cooling Richard Beasley Refrigerator & Freezer Repair 3 06-05-2009 02:23 PM
