Replacement parts for afb2534deb models | AppliancePartsPros.comSee the attachment for a tech sheet for a DEB3.
It should be a close if not the same as yours.
Your unit does not have a defrost timer, defrost is run from the main control board.
Your earlier problems may have been due to a thermistor or the control board.
Sounds like your current problem is a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle (see the tech sheet). The fans and compressor turn off when in defrost.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the board needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 15 in Section 4) from the wiring and measure it for continuity, around 30 ohms.
If the heater is OK
Remove one wire to the defrost thermostat (Item NI in Section 4 ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
