Replacement parts for 596-72282201 models | AppliancePartsPros.comLook under the unit for the tech sheet. It may also be paped to the inside of the back cover. It will tell you how to force a defrost. You will nknow youn are in defrost when the compressor and fans shut off.
Here is some info on forcing a defrost if you cannot find the tech sheet.
http://www.applianceaid.com/adaptive_defrost.htmlTry the Amana procedure and if that does not work try the last procedure.
[COLOR="DarkRed"]
Is it a simple fix by replacing the timer board??[/COLOR]
It is relatively simple just not that simple.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle, the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost board is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
