Discuss
Ice Maker not working
 in
Refrigerator & Freezer Repair
I discovered my ice make had not been producing ice. The ejector arm tongs were down in the cube maker
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker not working
  #1 (permalink)
Old 10-24-2007, 03:31 PM
mdmathis6 mdmathis6 is offline
Junior Member
mdmathis6 is on a distinguished road
Default Ice Maker not working
Model Number: ED5RHAXNQ   Brand: Whirlpool   Age: 1 - 5 years
I discovered my ice make had not been producing ice. The ejector arm tongs were down in the cube maker with no water/ice in the tray. This particular model has an infrared sensing system which shuts off the ice maker when the in door bin/ dispensor is full and it appears to be blinking when the door is opened. The sensor switch is in the on position.
So, I'm not sure where to look first...could the emitter/sensor switch system be faulty? Do I look next at replacing the whole ice maker system(as in motor being burned out)? Do I have a bad water valve/mechanism causing the whole system not to operate? I have no leaks and the water dispensor in the door works fine.
About 5 months ago I did have a ice cube jam which kept the rotor from moving, water was also frozen in the trays, keeping the ejector arm from rotating through. I melted the water out of the trays and freed the arm. I reset the arm but it still didn't operate until I cut the power to the fridge and restored it. This allowed the ice maker to start working again!
I tried the power trick this time but it didn't work. My only other trick will be to try a hair blower on the emitter and sensor lenses to see if frozen condensate might be blocking reception of the infrared light, there-by shutting down the whole unit.
Any other thoughts wuold be appreciated?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-24-2007, 04:19 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi mdmathis6
The first thing I would do is the ice maker optics diagnostics.
Based on the result of the diagnostics the optics or the ice maker has to be replaced.
- The part number for the optics boards AP3137510
- The part number for the ice maker AP2984633
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice Maker not working biglefti Refrigerator & Freezer Repair 2 11-29-2007 09:31 PM
Ice Maker Not Working Dennis Loose Refrigerator & Freezer Repair 0 10-08-2007 06:31 PM
Ice Maker still not working ShaneH Refrigerator & Freezer Repair 1 09-21-2007 03:08 AM
Ice Maker Stopped working Judymike08@yahoo.com Refrigerator & Freezer Repair 1 08-26-2007 08:56 AM
Ice maker not working stockit2me Refrigerator & Freezer Repair 3 08-04-2007 04:07 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
