Discuss
ice dispenser flap broken
 in
Refrigerator & Freezer Repair
I have an LG side by side with a water/ice dispenser on the freezer door. In the dispenser is a
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ice dispenser flap broken
  #1 (permalink)
Old 03-21-2011, 02:04 PM
Junior Member
bmiller108 is on a distinguished road
Default ice dispenser flap broken
Model Number: LRSC21935TT   Brand: -other-   Age: 1 - 5 years
I have an LG side by side with a water/ice dispenser on the freezer door. In the dispenser is a flap the size of a small coaster that appears to be on a spring and it seems that the spring has sprung. The flap will not close unless I reach up and do it by hand and I cannot get the dispensing unit apart to get inside and take a look. Anyone know how to get the face off of the dispensing unit and how I may be able to fix this once I do get it apart?
Ads By Google
Related Models
 LRSC21935TT Refrigerator
 LRSC21951ST Refrigerator
 LRSC26910SW Refrigerator
 LRSC26910TT Refrigerator
 LRSC26911SW Refrigerator
 LRSC26911TT Refrigerator
 LRSC26912SW Refrigerator
 LRSC26912TT Refrigerator
 LRSC26915SW Refrigerator
 LRSC26920SB Refrigerator
 LRSC26920SW Refrigerator
 LRSC26920TT Refrigerator
 LRSC26922SW Refrigerator
 LRSC26922TT Refrigerator
 LRSC26923SW Refrigerator
 LRSC26923TT Refrigerator
 LRSC26925SW Refrigerator
 LRSC26925TT Refrigerator
 LRSC26930SW Refrigerator
 LRSC26930TT Refrigerator
 LRSC26940ST Refrigerator
 LRSC26940TT Refrigerator
 LRSC26941SB Refrigerator
 LRSC26941ST Refrigerator
 LRSC26941SW Refrigerator
 LRSC26944SW Refrigerator
 LRSC26944TT Refrigerator
 LRSC26960TT Refrigerator
 LRSC26980SB Refrigerator
 LRSC26980TT Refrigerator
Maytag LRSD20A REF - SXS
 LRSPC2031BK Refrigerator
 LRSPC2031BS Refrigerator
 LRSPC2031T Refrigerator
 LRSPC2051ST Refrigerator
 LRSPC2331BS Refrigerator
 LRSPC2331W Refrigerator
 LRSPC2661T Refrigerator
 LRTB2023BS Refrigerator
Maytag LRTD17A REF - TOP MOUNT
Maytag LRTD19A REF - TOP MOUNT
Maytag LRTD23A Ref - Top Mount
 LRTN09314SW Refrigerator
 LRTN19310BQ Refrigerator
 LRTN19310WW Refrigerator
 LRTN19311SW Refrigerator
 LRTN22310SW Refrigerator
 LRTN22310TT Refrigerator
 LRTN22310WW Refrigerator
 LRTN22311TT Refrigerator
 LRTPC1831T Refrigerator
 LS-K2430CL Air Conditioner
 LS-K2430HL Air Conditioner
 LS-L1210CL Air Conditioner
Bosch LS010-000
 LS120CE.AWHAEUS Air Conditioner
 LS180CE.AWHAEUS Air Conditioner
 LS180HE Air Conditioner
 LS240CE.AWHAEUS Air Conditioner
 LS240HE Air Conditioner
Whirlpool LS6333LQ0 WASHER - DIRECT DRIVE
Whirlpool LSB6000LQ0 WASHER
Whirlpool LSB6000PQ0 AUTOMATIC WASHER
Whirlpool LSB6000PQ1 AUTOMATIC WASHER
Whirlpool LSB6000PQ2 AUTOMATIC WASHER
Whirlpool LSB6200KQ0 WASHER
Whirlpool LSB6200KQ1 AUTOMATIC WASHER
Whirlpool LSB6200PQ0 AUTOMATIC WASHER
Whirlpool LSB6200PQ1 AUTOMATIC WASHER
Whirlpool LSB6200PQ2 AUTOMATIC WASHER
Whirlpool LSB6300LQ0 WASHER - DIRECT DRIVE
Whirlpool LSB6300LW0 WASHER - DIRECT DRIVE
Whirlpool LSB6300LW1 AUTOMATIC WASHER
Whirlpool LSB6300LW2 AUTOMATIC WASHER
Whirlpool LSB6300LW3 AUTOMATIC WASHER
Whirlpool LSB6300PW0 AUTOMATIC WASHER
Whirlpool LSB6300PW1 AUTOMATIC WASHER
Whirlpool LSB6300PW3 AUTOMATIC WASHER
Whirlpool LSB6300PW4 AUTOMATIC WASHER
Whirlpool LSB6400KQ0 WASHER
Whirlpool LSB6400KQ1 WASHER
Whirlpool LSB6400LW0 WASHER - DIRECT DRIVE
Whirlpool LSB6400LW1 AUTOMATIC WASHER
Whirlpool LSB6500PW0 AUTOMATIC WASHER
Whirlpool LSB6500PW1 AUTOMATIC WASHER
Whirlpool LSB6500PW2 AUTOMATIC WASHER
Whirlpool LSB6500PW3 AUTOMATIC WASHER
Whirlpool LSB6500PW4 AUTOMATIC WASHER
 LSC21943ST Refrigerator
 LSC26905SB Refrigerator
 LSC26905SW Refrigerator
 LSC26905TT Refrigerator
 LSC26945SW Refrigerator
 LSC26945TT Refrigerator
 LSC27910SB Refrigerator
 LSC27910ST Refrigerator
 LSC27910SW Refrigerator
 LSC27910TT Refrigerator
 LSC27926SB Refrigerator
 LSC27926ST Refrigerator
 LSC27926SW Refrigerator
 LSC27926TT Refrigerator
 LSC27931SB Refrigerator
 LSC27931ST Refrigerator
 LSC27931SW Refrigerator
 LSC27950SB Refrigerator
 LSC27950ST Refrigerator
  #2 (permalink)
Old 03-22-2011, 07:59 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
BMiller,
Here are the instructions on servicing the dispenser assembly, from the service manual for your refrigerator.
Just remember to unplug the power cord first,
Take your time, and be cautious with the trim parts, and wiring to the control.
Once you're dismantled, you'll be able to determine how to reinstall or replace the tension spring.
The hardest part is getting into the dispenser, the rest of he repair is pretty simple.
Good Luck,
5. DISPENSER
1) Disconnect button assembly by pulling down until it
stops and then pulling forward.
2) Remove display frame Assembly by making a gap
between the display frame Assembly. and funnel
Assembly. with a flat blade screwdriver and pulling it
forward. The cover dispenser is fixed with a hook.
3) Display Assembly can be disconnected by pressing the
upper part of the cover dispenser and pushing the display
Assembly. after disconnecting the dispaly frame Assembly Housing.
4) Loosen four screws with a phillips screwdriver and pull out the
funnel Assembly to disconnect.
5) Duct cap Assembly is disconnected if hold lever
connecting screw is loosened with a phillips screwdriver.
6) For assembling the duct cap Assembly, insert one end of a
spring into the right hole of dispenser lever, and insert
the other end into the right hole in upper part of the
dispenser. And then assemble the holder lever after fixing
the holder at the solenoid Assembly working part.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice dispenser flap won't open Ricki Refrigerator & Freezer Repair 1 11-16-2010 08:19 PM
ice dispenser door flap margt Refrigerator & Freezer Repair 0 03-30-2010 03:45 PM
flap on ice dispenser won't close stacylynne Refrigerator & Freezer Repair 0 08-13-2009 09:23 PM
Ice Dispenser flap not sealing rmcveigh Refrigerator & Freezer Repair 4 06-07-2009 09:04 PM
Dispenser flap won't close. Jaxom Refrigerator & Freezer Repair 6 05-03-2009 07:27 PM
