My GE French door bottom freezer will not keep it's temperature. Both the refrigerator and freezer cycle from cold to warm every 24 hours. I think it is the main control board does anyone have another idea on what causing the problem?
Make sure your condesor is clean. is the evap fan running, condensor fan running.
Thanks. I did clean the the compresor area with the vaccum. the fan seemed to be working OK. When I resarted the unit it did go back to tempature for a while and then it just starting getting warm again. I did leave it on over night but it keeps going from cold to hot and then hot to cold.
