Not sure of actual age. Need to replace door gasket seals on both freezer and fridge. Unit is side by side. Interior plastic door liners are cracked and don't screw tight to door. Screws go through liner then gesket into door. Can I drill new holes through liner,gasket then into doors without harming anything and get good seal?
