I had what appeared to be a leak at the junction of the fill tube and the fitting that goes into the freezer compartment from the rear panel of the box. I replaced the clamp with a tradional hose clamp and the leak stopped, but the freezer started to have leak above and in the ice bin which was filled with a solid ice block(no cubes)
