Amana side by side not cooling
Model Number: SZD25S5L Brand: Amana Age: 5 - 10 years
I replaced the over load with a part I bought from Appliance Pros Parts, the picture on their site showed two full length prongs on the part, when I received the part one of the prongs was short but would still hold the connector, black wire I assume that leads to the compressor motor according to the schematic. Before I replaced this part the compressor would kick in after the refer was unplugged for several hours, I would plug in the refer and the compressor would run and everything would cool, then it would kick out and the refer fan would stop running, inside light still on. Once I replaced the over load with the new part, at first the compressor seemed to be working but was not cooling as much as it should but then went to not cooling at all but the refer fan in the back would continue to run this time but the no air circulating into the freezer or the refer section. There is a part connected underneath the over load, it's brown in color and connects to the compressor directly underneath the over load, is this the capacitor, if so I can't seem to find it on Appliance Pros, the number on this part goes something like this:
8EA 403
27 F5R
Mexico
Obvioulsy made in mexico, any help out there? Not quite sure where to go from here.
Ads By Google
Related Models
