Originally Posted by: 123-rybo my frig and freezer is cooling fine but is runing all the time it will run for about 30 min then it will shut off but only for about 15 min then kicks back on even if i keep the door closed.any ideas to what is going on? Rybo, Two things, Check and clean the door gasket and front flange, check the gasket for a tight fit against the flange and any torn areas(especially) in the hinge side corners on the flat seal area. Move the unit away from the wall(unplug the power cord) Remove the front kick plate grille, and the lower access panel on the back of the refrigerator, Clean all the lint off the coils, fans and motor from both ends(front and back). Remove all the debris, lint, dust,etc. from the floor and walls under and surrounding the unit. Good Luck, :) :) :)
