Ice dispencer flapper is broken on left side. Ice maker and water work but you have to manually fit flapper back after each use. What parts do I order and do I pull the front control panal off? Thanks
I have the exact same problem. Same side broke. I found a part "Ice door fountain kit" which includes a few parts including the flapper. Did you get any answers? Have you fixed it on your own yet? Wondering if I have to buy all the extra parts in the kit? Did you have to take the front panel off? Any advice?? Thnx
