Discuss
Fridge inop,Freezer inop
 in
Refrigerator & Freezer Repair
Just this Satarday it just stopped cooling.I defrosted it today figuring that may be a problem,Also vacumed all
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Fridge inop,Freezer inop
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-22-2007, 07:16 PM
35mastr 35mastr is offline
Junior Member
35mastr is on a distinguished road
Default Fridge inop,Freezer inop
Model Number: ED2FTGXKQ00   Brand: Whirlpool   Age: 1 - 5 years
Just this Satarday it just stopped cooling.I defrosted it today figuring that may be a problem,Also vacumed all the coils under the unit.Plugged it in this evening and still no cooling.Air is being blown in through the freezer ducts but it is just ambiant temp air.Any suggestions.Fridge side also inop
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-22-2007, 07:40 PM
jdappl07 jdappl07 is offline
Senior Expert
APP Volunteer
jdappl07 is on a distinguished road
Default repair
Verify if the compressor is running and the small copper line is hot if not no compressor running check relay before replacing compressor
also check condensor fan is running had problem with past models
  #3 (permalink)
Old 10-22-2007, 07:43 PM
Junior Member
Default
Compressor not running and lines are cold.Where is that relay located?Also how do you check it?Compressor also hot to the touch but all lines are cold.Fan is running constantly.
  #4 (permalink)
Old 10-22-2007, 07:55 PM
Senior Expert
APP Volunteer
Default
unplug the machine and relay is on the left side of the comp pull it off slowly it will be resistance then look for burnt spots or shake it if it rattles good its bad replace relay
  #5 (permalink)
Old 10-22-2007, 08:33 PM
Junior Member
Default
Pulled the relay.No visible burn spots.But it does rattle alot and small metal particles fall out of it on the plug side.Iam going to get one in the morning.Thanks for all your help.I will let you know how I make out tomorrow
  #6 (permalink)
Old 10-24-2007, 08:22 AM
Junior Member
Default
Replaced the relay and its now up and running,Thanks jdappl07 you were a great help.If you ever need and car help you can find me here at either of these sites under the same user name as here.
Club Hot Rod - Club Hot Rod
Rat Rods Rule Forums - Powered by vBulletin
Again thanks a bunch.
Now to figure out my microwave problem
George
__________________
George
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
microwave inop Phil Miller Microwave Repair 1 10-21-2007 09:04 PM
Fridge & Freezer not working tgammons Refrigerator & Freezer Repair 1 10-08-2007 03:32 AM
freezer ok, fridge not cooling 535bimmer Refrigerator & Freezer Repair 0 09-04-2007 03:28 PM
Countdown Display INOP, Washer cycles normally Julia Dishwasher Repair 0 08-20-2007 09:03 PM
Ice dispenser is inop jodava Refrigerator & Freezer Repair 1 07-30-2007 06:01 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
