automan69
#1 Posted : Monday, December 29, 2008 1:57:21 PM(UTC)
automan69
freezer on bottom freezes but refrigerator won't drop below 60
Eddie365
#2 Posted : Monday, December 29, 2008 2:18:11 PM(UTC)
Eddie365
Hi, You can start checking the evaporator coil is not ice up
and to make sure your evaporator fan is running.
If it is ice up you have a defrost problem, you will need to check
your heater and your defrost t-stat located on evaporator coil
if heater is good replace Defrost t-stat and clean all the ice in the coil.
automan69
#3 Posted : Tuesday, December 30, 2008 7:53:38 AM(UTC)
automan69
cleaned condenser set t-stat @ 5 checked this morning temp at 38-40 degrees don't know what was wrong but working now
knoxtoy87
#4 Posted : Tuesday, December 30, 2008 9:46:15 PM(UTC)
knoxtoy87
condensor really dirty? that could be it.
