Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   Outside Refrig/Freezer in Garage does not stay cold in cold weather (http://forum.appliancepartspros.com/refrigerator-freezer-repair/18616-outside-refrig-freezer-garage-does-not-stay-cold-cold-weather.html)
verno1 12-29-2008 01:54 PM
We have this same problem every winter when the outside temp drops below 20 degrees.
The freezer starts to thaw out the frozen foods and the refrigerator does not seem to get as cold.
This unit is installed in our attached garage. It works fine otherwise. You can hear the compressor kick on. Is is something to do with the exterior moisture setting?
Please help before I lose all of my meat!
Drags1998 12-29-2008 03:09 PM
This unit WILL NOT WORK IN A COLD GARAGE!!!! It MUST be in a 60-65 degree Minumum room!!!!!
SuzyJazz 12-14-2010 12:07 PM
mrt15csew4
I have this model in my garage and it is COLD out there. The fridge with run for a while but then pops the breaker. Do you think if I bring the fridge in the house it will solve the problem??
