The defrost timer appears to be working fine, The evaporator has no frost on it, the defrost element is working the evaporator pan heater is working, the evaporator fan is working. I tested the freash food damper control with ice, it appears to extending, however no air is felt in the refrigerator section. The freezer is at @6 degrees while the refrigerator is at @55 degrees. Please help
