| » Defrost timing |
Model Number: KSRG25FKSS16 Brand: Kitchen Aid Age: 1 - 5 years
Could someone tell me what determines when this refrigerator decides to defrost. I have checked out the heater etc.by the test method used to tell the control board to start defrost and everything mechanical works. What tells the board when to defrost. Door openings? once a day?
It depends on compressor run time, tempurature and the door openings. It is primarily about every 8 hours.
Is it defrosting? If not test the defrost thermostat and heater. Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
I forced a defrost by using the procedures outlined in the electric schematic to tell the board to order a defrost and the refrigerator defrosted. Is their a way to tell if the boar is recieving the compressor on and off time as well as the door openings? Or do i just asume it is the board and replace it?
If you followed the proceedure for the board to kick it into defrost, did it go into defrost mode? If not test the defrost thermostat first (aka bi-metal) with an ohm meter. If it has continuity ohm the defrost heater if it has continuity then the board is the problem.
Nat
__________________
Yes the defroster works. I now believe either the board is bad or the wires connecting the compressor or the door opening counter are comprimised. Since the compressor shuts off during defrost I will assume they are ok. and check the door opening connection. If this is ok does this mean the board is bad?
I think the adaptive defrost board is your problem.
Nat
__________________
Anytime! Keep us all posted.
Nat
__________________
| Display Modes | |
| timing diagram | bquestions | Dishwasher Repair | 2 | 09-20-2010 09:44 AM |
| ice maker timing | cigarettesteve | Refrigerator & Freezer Repair | 0 | 01-31-2010 11:34 AM |
| Maytag washer timing issues? | Craig603 | Washer Repair | 1 | 12-21-2009 07:07 PM |
| Maytag Electric Dryer Timing Cycle | GlennAbello | Dryer Repair | 3 | 08-05-2009 08:13 AM |
| Ice Maker timing is way off! | rowley978 | Refrigerator & Freezer Repair | 0 | 07-21-2009 06:14 PM |
