djohnson4
#1 Posted : Wednesday, March 9, 2011 10:28:57 AM(UTC)
djohnson4
The freezer worked fine until I moved it. I have heard you can damage your freezer if you do not handle it properly when moving it. Now it will freeze, then it will quit freezing after awhile and everything will thaw and it will not go back to freeze. I can unplug it and try again and it will do the same thing. It will just not keep the temp at freezing.
Fridge too warm due to one of two air vents in the fridge section of a fridge freezer not working (Refrigerator & Freezer Repair)
by mungbeans 7/15/2023 1:08:45 PM(UTC)
Amana Fridge Freezer and refrigerator too warm (Refrigerator & Freezer Repair)
by donc 4/9/2022 7:22:56 PM(UTC)
GE freezer keeps having to be defrosted (Refrigerator & Freezer Repair)
by Guest 4/7/2022 11:46:37 AM(UTC)
GE freezer section too hot on defrost (Refrigerator & Freezer Repair)
by CoolGuy247 12/21/2021 6:53:43 AM(UTC)
GE Freezer at 0 degrees and fefrigerator side 57 degrees (Refrigerator & Freezer Repair)
by Guest 11/22/2021 8:23:05 AM(UTC)
Frost and ice in GE Freezer even with tight door gasket seal (Refrigerator & Freezer Repair)
by EEEng 11/12/2021 8:16:13 AM(UTC)
GE freezer temperature varies a lot.(45F to -10) daily. (Refrigerator & Freezer Repair)
by cijojohn1 8/4/2021 10:02:45 AM(UTC)
Admiral ss fridge freezer damper door freezing open Please help (Refrigerator & Freezer Repair)
Belarus swingbyte 4/1/2021 11:35:24 PM(UTC)
GE Freezer (PFS22SISBSS) gets warm sporadically (Refrigerator & Freezer Repair)
by vsanghvi 1/2/2021 4:25:15 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Freezer is not Freezing (Refrigerator & Freezer Repair)
by MrChip 10/23/2019 8:52:01 AM(UTC)
side by side GE Freezer problem (Refrigerator & Freezer Repair)
by Louise11 10/10/2016 2:28:22 PM(UTC)
GE Freezer not cooling (Refrigerator & Freezer Repair)
by Jmire1981 8/31/2016 5:49:08 AM(UTC)
GE fridge freezer problems (Refrigerator & Freezer Repair)
by robinleigh 2/16/2016 5:33:39 PM(UTC)
Ge freezer working, fridge won't get colder than 45 (Refrigerator & Freezer Repair)
by Purpleturtle 7/23/2015 7:59:56 PM(UTC)
