The freezer worked fine until I moved it. I have heard you can damage your freezer if you do not handle it properly when moving it. Now it will freeze, then it will quit freezing after awhile and everything will thaw and it will not go back to freeze. I can unplug it and try again and it will do the same thing. It will just not keep the temp at freezing.
