Sears Chest freezer door won't stay open
Refrigerator & Freezer Repair
This freezer is 35 years old, and still works just fine, albeit not very efficiently. The door on this chest-type
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Sears Chest freezer door won't stay open
  #1 (permalink)
Old 12-28-2008, 11:22 AM
Junior Member
vettman is on a distinguished road
Default Sears Chest freezer door won't stay open
Model Number: 19871n22   Brand: Sears   Age: More than 10 years
This freezer is 35 years old, and still works just fine, albeit not very efficiently. The door on this chest-type freezer used to stay open when lifted to the fully open position, but now it won't stay open. I have searched for some way to tighten/adjust the hinges, but don't see any access. Is there some method to adjusting the door so that it will once again stay open?
Related Models
Kenmore 198724060 COLDSPOT FREEZER
Kenmore 198724090 COLDSPOT FREEZER
Kenmore 198725060 COLDSPOT FREEZER
Kenmore 198725090 COLDSPOT FREEZER
Kenmore 198726060 COLDSPOT FREEZER
Kenmore 198726070 COLDSPOT FREEZER
Kenmore 198727060 FREEZER
Kenmore 198727090 FREEZER
Kenmore 1987280610 FREEZER
Kenmore 1987280613 FREEZER
Kenmore 1987280920 FREEZER
Kenmore 1987290683 FREEZER
Kenmore 1987290920 FREEZER
Kenmore 1987801 COLDSPOT ICE MAKER
Kenmore 1987802 COLDSPOT ICE MAKER
Kenmore 1987854820 COLDSPOT ICE MAKER
Kenmore 1987864820 COLDSPOT ICE MAKER
Kenmore 1987864821 ICEMAKER
Kenmore 1988100581 FREEZER
Kenmore 1988100582 FREEZER
Kenmore 1988100681 FREEZER
Kenmore 1988100682 FREEZER
Kenmore 1988100980 FREEZER
Kenmore 1988101510 FREEZER
Kenmore 1988101512 FREEZER
Kenmore 1988101530 FREEZER
Kenmore 1988101532 FREEZER
Kenmore 1988101537 CHEST FREEZER
Kenmore 1988101538 SEARS CHEST FREEZER
Kenmore 1988101539 FREEZER
Kenmore 1988101550 FREEZER
Kenmore 1988101551 FREEZER
Kenmore 1988101552 FREEZER
Kenmore 1988101553 FREEZER
Kenmore 1988101583 FREEZER
Kenmore 1988101832 CHEST FREEZER
Kenmore 1988101837 SEARS CHEST FREEZER
Kenmore 1988101839 CHEST FREEZER
Kenmore 1988101842 FREEZER
Kenmore 1988101850 FREEZER
Kenmore 1988101851 FREEZER
Kenmore 1988101852 FREEZER
Kenmore 1988101853 FREEZER
Kenmore 1988101882 FREEZER
Kenmore 1988102330 FREEZER
Kenmore 1988102339 CHEST FREEZER
Kenmore 1988102340 FREEZER CABINET PARTS
Kenmore 1988102350 FREEZER
Kenmore 1988102353 FREEZER
Kenmore 1988102380 FREEZER
Kenmore 1988102381 FREEZER
Kenmore 1988110512 FREEZER
Kenmore 1988110515 COMPACT CHEST FREEZER
Kenmore 1988110582 CHEST FREEZER
Kenmore 1988110682 FREEZERS
Kenmore 1988110980 FREEZER
Kenmore 1988111285 CHEST FREEZER
Kenmore 1988111552 FREEZER
Kenmore 1988111582 FREEZER
Kenmore 1988111852 CHEST FREEZER
Kenmore 1988111853 FREEZER
Kenmore 1988112330 FREEZER
Kenmore 1988112337 SEARS CHEST FREEZER
Kenmore 1988112350 FREEZERS
Kenmore 1988112380 FREEZER
Kenmore 1988112730 FREEZER
Kenmore 1988120582 SEARS CHEST FREEZER
Kenmore 1988120682 CHEST FREEZER
Kenmore 1988120910 FREEZER
Kenmore 1988120912 CHEST FREEZER
Kenmore 1988120982 CHEST FREEZER
Kenmore 1988120985 COMPACT FREEZER
Kenmore 1988121235 CHEST FREEZER
Kenmore 1988121285 SEARS CHEST FREEZER
Kenmore 1988121532 SEARS CHEST FREEZER
Kenmore 1988121537 CHEST FREEZER
Kenmore 1988121582 CHEST FREEZER
Kenmore 1988121842 SEARS CHEST FREEZER
Kenmore 1988121847 SEARS CHEST FREEZER
Kenmore 1988121852 SEARS CHEST FREEZER
Kenmore 1988122330 SEARS CHEST FREEZER
Kenmore 1988122337 SEARS CHEST FREEZER
Kenmore 1988122350 CHEST FREEZER
Kenmore 1988122730 CHEST FREEZER
Kenmore 1988130582 CHEST FREEZER
Kenmore 1988130585 CHEST FREEZER
Kenmore 1988130982 CHEST FREEZER
Kenmore 1988130985 CHEST COMPACT FREEZER
Kenmore 1988131235 CHEST FREEZER
Kenmore 1988131236 CHEST FREEZER
Kenmore 1988131237 CHEST FREEZER
Kenmore 1988131285 CHEST FREEZER
Kenmore 1988131286 CHEST FREEZER
Kenmore 1988131287 CHEST FREEZER
Kenmore 1988131512 CHEST FREEZER
Kenmore 1988131513 CHEST FREEZER
Kenmore 1988131515 CHEST FREEZER
Kenmore 1988131532 CHEST FREEZER
Kenmore 1988131533 CHEST FREEZER
Kenmore 1988131537 CHEST FREEZER
Kenmore 1988131538 CHEST FREEZER
Kenmore 1988131552 CHEST FREEZER
Kenmore 1988131582 CHEST FREEZER
Kenmore 1988131583 CHEST FREEZER
Kenmore 1988131842 CHEST FREEZER
Kenmore 1988131843 CHEST FREEZER
Kenmore 1988131872 CHEST FREEZER
Kenmore 1988131873 CHEST FREEZER
Kenmore 1988132330 CHEST FREEZER
Kenmore 1988132331 CHEST FREEZER
Kenmore 1988132332 CHEST FREEZER
Kenmore 1988132337 CHEST FREEZER
Kenmore 1988132338 CHEST FREEZER
Kenmore 1988132350 CHEST FREEZER
Kenmore 1988132351 CHEST FREEZER
Kenmore 1988132352 CHEST FREEZER
  #2 (permalink)
Old 09-25-2009, 05:33 PM
Junior Member
Homeowner1270 is on a distinguished road
Default We had the same problem
Our Sears chest freezer had the same problem. Our root problem may or may not be the same as yours. We found out that the problem was caused by an accumulation of ice hidden in the inside of the lid, which made the lid too heavy for the hinge springs. After defrosting the entire freezer, including allowing enough time for all the ice in the lid to melt, then the lid was a ton lighter, and the hinge springs were able to keep the lid open.
  #3 (permalink)
Old 12-20-2010, 03:46 AM
Junior Member
bgkaufman is on a distinguished road
Default now my freezer door stays open. Defrosting top using hairdryer worked;water out seal
Now my freezer door stays open. Defrosting top using hairdryer worked;water comes out seal and I kept putting rags to gather up the water. First I had used the flash defrost to defrost the main part of the Sears freezer, but it didn't seem to do anything for the top. Used hair dryer inside the top for quite a while, then used it on the metal top. I had been concerned about where the water that was defrosted would go to. Not a problem as it comes out the seal at the bottom as well as a bit by the light. I had usually defrosted the freezer more, so not sure if this is why this is the first time I had the problem. I also don't know if possibly I need to get a new seal -- anyone have thoughts on that??
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
sears coldspot chest freezer Buzzvs Refrigerator & Freezer Repair 1 10-16-2011 05:29 AM
Freezer Door Won't Stay Open bobskorney Refrigerator & Freezer Repair 1 11-10-2009 05:08 AM
Sears chest freezer will not turn on jigs Refrigerator & Freezer Repair 2 03-22-2009 10:51 AM
oven door won't stay open mtrimboli Oven Repair (including Ranges and Cooktops) 14 12-12-2007 05:36 PM
sears (gibson) chest freezer won't cool moegs Refrigerator & Freezer Repair 1 08-03-2007 11:01 AM
