| » GE side by side freezor and frig not cooling |
Model Number: GSS25QGMD WW Brand: GE Age: 5 - 10 years
Have a GE GSS25QGMD WW side by side. Freezer quit working first then refrig. All lights work, water and ice augur working. Condensor and evaporator fan working. Compressor not running (no voltage to compressor). I do have the electrical diagram
I just fixed one today. The evaporator thermistor was missing from a previous boched repair and the defrost thermostat was blown out.The fridg just hung up in defrost like yours. With the infinite resistance of the thermistor, the computer sensed -40 degrees which represents high resistance per the chart I put in the sticky for these refrigerators.
You can check the motherboard pin J1-5 to J1- 2 for the thermistor resistance value.
__________________
Rich, I did your above recommendation and the thermistors tested 5.8 6.2 & 5.8 on the 20k scale. Any other suggestions? I found this information on appliance-repair-it.com "If the fan is running but the compressor is not, then the main board is more than likely the problem. But it could also be start relay. If the start relay is bad the compressor will try to start every so often (every 3-5 minutes). If this is happening replace the start relay and if not the main board is the problem". This kinda goes back to your original comment about a possible bad solder joint. Of course my compressor doesn't run at all. So between J8 and orange on the motherboard I should have 115v. I don't, so that points to a motherboard problem. There is a comp relay on the motherboard is this replaceable? or are there test points to point to a low/high voltage problem on the board. Thanks again for your reply. |
| Display Modes | |
| not cooling in frig side | doug55 | Refrigerator & Freezer Repair | 1 | 12-02-2010 09:48 AM |
| amana frig/freezer side by side | lindal | Refrigerator & Freezer Repair | 0 | 06-28-2010 01:21 PM |
| Refridgerator side-by-side not cooling (refridge side) | rrvolfan | Refrigerator & Freezer Repair | 2 | 05-31-2010 11:10 AM |
| Kenmore Frig & Freezer not cooling on either side | Resinman | Refrigerator & Freezer Repair | 6 | 03-25-2009 06:09 PM |
| Top of Freezer and top of Frig not cold enough on side by side | PleaseHelp | Refrigerator & Freezer Repair | 1 | 11-13-2008 10:09 AM |
