Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   My freezer works fine my fridge side is not cooling (http://forum.appliancepartspros.com/refrigerator-freezer-repair/180856-my-freezer-works-fine-my-fridge-side-not-cooling.html)
Eperalta08 02-28-2011 09:42 PM
Can someone give me some advise I have a refrigerator that my fridge side is not working that good its a litle cold but then it gets a litle warm my freezer side works perfectly, also on the freezer side it has a red blinking light the ice maker works fine. Can someone help.
Jeff / APP Team 03-01-2011 01:38 PM
Do you have frost build up on the back freezer wall? If so you have a defrost problem. You will need to test the defrost thermostat and heater. They should read closed or 0 for continuity when cold. If they test good then you need to change the control board. Also check and see if the evaporator fan is running. If not, this can cause the cooling problem as well. Here are the links for these parts. Hope this helps.
Part number: AP4299920
Part number: AP3756388
Part number: AP3950825
Part number: AP2988898
