Discuss
Refrigerator not cooling, fan working, compressor hot but not running
 in
Refrigerator & Freezer Repair
The compressor has been running for a couple of days. Never actually did a complete defrost because it didn't appear
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator not cooling, fan working, compressor hot but not running
  #41 (permalink)
Old 12-22-2012, 02:41 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
The compressor has been running for a couple of days. Never actually did a complete defrost because it didn't appear to need it. Still a sealed system issue?
The above seems to indicate that you do not quite understand how defrost works. It is a timed event the unit does not sense when it needs a defrost.
If the unit has a defrost timer then every 8 hours or so it does a defrost for about 30 minutes.
If the unit has an adaptive defrost board then often it monitors how often the doors open and from that decides when it should run the 30 minute defrost cycle.
One thing that can stop defrost is the defrost thermostat, it kills power to the defrost heater (wired in series). It opens just above freezing. But the unit still goes through the 30 minute defrost cycle but the heater does not come on.
Yes it still sounds like a sealed system problem to me.
Any idea why the water quit?
Sorry I cannot say.
Ads By Google
__________________
  #42 (permalink)
Old 12-30-2012, 11:15 AM
Junior Member
bfgoodmudder is on a distinguished road
Default
Ok, after speaking with a local repair shop it's been determined that it's not a sealed system issue but an evaporator fan issue. Now all I have to do is figure out how to get to it. Anybody have any ideas?
  #43 (permalink)
Old 01-23-2013, 08:26 PM
Junior Member
shasbrooke is on a distinguished road
Default Kenmore 25378132892 wont get cold
Like others, door left open over night. Fan working, compressor seems to be running, but gets very hot. removed back panel of freezer and top right corner of coils is freezing over. Did a 24 hour defrost and plugged back in. same issues persist and air seems warmer now. Removed connections to compressor and tested 3 prongs each to each other. Readings were 10.7, 6.3, and 3.4. Also tested for continuity by scratching off paint chip and connecting one end to that spot and other to each prong and each reading was 0 using the "V" setting on the multitester (not sure if that is what i want). Also, not sure if it is relevant, but within minutes of plugging it back in after defrost, the coils in back of freezer compartment began to ice over. I'm not certain what to check next. Any direction would be appreciated.
  #44 (permalink)
Old 01-23-2013, 09:56 PM
Junior Member
Default
Quote:
I never did a defrost. All was well within 24hrs of replacing evaporator fan. Compressor should be warm, not necessarily hot or too hot to touch. Also, which fan is running? There's a compressor fan and the evaporator fan which (on mine) is inside the rear freezer panel. If it's not running, it's not circulating air to the rest of the freezer, or the fridge side. This was my entire issue. I pulled the inner panel, pulled the fan, checked for voltage at the fan terminals(3 of them), and came to the conclusion that the fan was bad. 22 bucks on ********. Problem solved.
V would probably be volts. Continuity will be a different setting on your meter. Might look like an arrow/plus sign type of symbol. Those readings don't ring a bell but you should be able to look them up. I found youtube helpful
Let us know what you find out. It's always a pain in the ass til ya fix it.
  #45 (permalink)
Old 01-24-2013, 12:27 AM
Junior Member
Thanks BFGOODMUDDER. Here are responses to your statements and questions:
I was able to determine the continuity setting on the multitester and all the terminals tested out fine. So, that doesn't seem to be the issue.
The fan I referred to in my earlier post was the evaporator fan located behind (attached to) the back panel inside the freezer. It is running just fine. I'm not certain if my unit has a condenser fan as I am unable to locate it and I cant find anything published about my model having one.
Compressor is warm/hot to the touch, but not to the degree where i would not be able to continue holding my hand on it.
What am I missing? What is most likely the next potential cause of the issue that I can test? Thermostat? Defroster? Defrost timer? Capacitor?
I attached a couple pictures of what the freezer coils look like when frozen.
Thanks again for your insight.
  #46 (permalink)
Old 01-24-2013, 07:28 AM
Jeff / APP Team's Avatar
Senior Expert
Jeff / APP Team is on a distinguished road
Default
Based on the pictures you provided, there is no defrost issue. You have a restriction or a low freon issue causing the problem with the unit. This will require an HVAC tech to repair the sealed system on the unit.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Jeff K. / APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #47 (permalink)
Old 01-24-2013, 11:44 AM
Junior Member
Default
If the evaporator fan is running I'm stumped on that one. That's about what my coils looked like. Evaporator fan replacement fixed the issue for me. I would make absolutely sure you've identified the evaporator fan and that it is running. I also called a local fridge repair shop when I was having issues. The guy immediately told me what my issue was and had no idea what I was talking about when I mentioned a sealed system issue. They only charge 10 bucks for a service call so maybe you can find somebody like that where you are.
  #48 (permalink)
Old 01-24-2013, 12:42 PM
Senior Expert
Default
Based on the photos provided, this is not a fan motor issue. If it was a fan motor, the coils would still have frost all over them with some build up on the top. These coils are clean, except where the freon enters the coils. This appears to be a sealed system issue.
__________________
Jeff K. / APP TEAM
  #49 (permalink)
Old 01-25-2013, 07:39 PM
Junior Member
Default
Thanks for all the great words of wisdom. Assuming it is a sealed system issue caused by a restriction in the line, I have read that i am better off investing in a new fridge. Is that right? If that is the case (meaning i will be parting ways with this fridge), this is going to sound silly probably.... why cant i just tap (beat) on the line where the restriction seems to be present in hopes that I will dislodge whatever the restriction is? Is that even possible? What about removing just that section of aluminum and copper, cleaning it out, reconnecting and recharging? Please don't laugh too hard if that makes no sense. Thanks.
  #50 (permalink)
Old 01-25-2013, 08:04 PM
Junior Member
Default
Lotsa good info out there..... https://www.google.com/search?q=seal...ient=firefox-a
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Not cooling. Compressor bumps on then off. Fans running. afterhourstvrepair Refrigerator & Freezer Repair 3 12-30-2012 11:28 AM
Refrigerator not cooling/compressor making funny sound koehler Refrigerator & Freezer Repair 4 04-10-2010 07:43 AM
Refrigerator running but not cooling? teamster1 Refrigerator & Freezer Repair 1 11-23-2009 03:20 AM
motor is running but refrigerator and freezer are not cooling marnita61 Refrigerator & Freezer Repair 1 10-26-2009 05:06 PM
Refrigerator running but not cooling williamclydemoon Refrigerator & Freezer Repair 1 10-17-2007 03:13 AM
