Discuss
Refrigerator not cooling or freezing
 in
Refrigerator & Freezer Repair
As you can see from the model and age of the fridge, it is pretty old, it think. Well it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator not cooling or freezing
  #1 (permalink)
Old 10-20-2007, 01:22 AM
diaz1023 diaz1023 is offline
Junior Member
diaz1023 is on a distinguished road
Default Refrigerator not cooling or freezing
Model Number: frt21nnhb1   Brand: Frigidaire   Age: 5 - 10 years
As you can see from the model and age of the fridge, it is pretty old, it think. Well it stopped cooling and freezing, my icecream is melting and that is making me sad , How do I go about seeing what is wrong with it? I believe you can all help me and it would be greatly appreciated
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-20-2007, 04:08 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Remove back freezer panel and check frost pattern, if only partially frosted, you have a refrigeration system problem for a pro. to fix. If no frost, check your compressor. If not running and all fans running, you may just have a bad start relay.
I would check your three compressor pins for ohms. If ok, just replace the start relay. Click on your model # to get it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer and Fridge not cooling/freezing moderdm Refrigerator & Freezer Repair 5 10-04-2008 07:50 PM
fridge and freezer not cooling or freezing gunner_guy26 Refrigerator & Freezer Repair 5 07-23-2008 02:10 PM
Freezer freezing ok refrigerator not cooling Frenchie Refrigerator & Freezer Repair 4 01-08-2008 04:01 AM
crosley shelvador fridge not freezing or cooling hear clicking noise noddef2000 Refrigerator & Freezer Repair 3 08-27-2007 09:11 PM
Whirlpool Refrigerator not freezing or cooling KPW Refrigerator & Freezer Repair 0 08-13-2007 06:38 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
