Discuss
fan motor replacement
 in
Refrigerator & Freezer Repair
I ordered a fan motor only replacement part #AP4140906 and two new gromments, instead of the complete fan motor and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » fan motor replacement
  #1 (permalink)
Old 02-25-2011, 09:20 AM
Junior Member
buckit is on a distinguished road
Default fan motor replacement
Brand: Samsung   Age: 5 - 10 years
I ordered a fan motor only replacement part #AP4140906 and two new gromments, instead of the complete fan motor and housing, for my 2004 Samsung model #RS2630SH. My ? is how detailed of a job this is gonna be or just a simple repacement into the original housng to restore this compressor componets cooling gem.
Thanks,
Frank
  #2 (permalink)
Old 02-25-2011, 10:02 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Thanks,
Frank
Frank,
Not that major a repair,
The best way, is to remove the whole assembly,
Be careful, there's a lot of sharp edges,
And that housing is a "snap" fit into the base of the compartment.
The condenser Fan is located in the middle of
machine compartment. It cools down the subcondenser
and the compressor.
1. Lift up the rib under the motor support.
2. Pull the support motor.
Not a lot if information from the service manual.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 02-25-2011, 10:16 AM
Junior Member
Default
Thanks,
Frank
Thanks Joe, your advise is what I was hoping to hear.
  #4 (permalink)
Old 02-25-2011, 11:50 AM
Senior Expert
Default
Our pleasure to help,
Drop us a line when you're done, and let us know how you did.
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 03-02-2011, 01:14 PM
Junior Member
Default fan blade removal
Thanks,
Frank
Joe,
How do remove the fan blade to remove and replace the defective motor I inquired about installing? Thanks
Frank(buckit)
  #6 (permalink)
Old 03-02-2011, 03:58 PM
Senior Expert
Default
Joe,
Frank(buckit)
Frank,
As I mentioned, not a lot of service information,
As best I can tell, and remember,
The fan blade is held in place by a small metal spring clamp, on the center hub of the fan blade, or is a pressure fit and will pull off.
The fan motor itself is mounted to the support assembly by 2 rubber grommets, one on each side of the motor shaft/housing in the center of the motor itself.
I guess I mis understood your original question.
__________________
Joe M. APP TEAM
  #7 (permalink)
Old 03-03-2011, 04:33 PM
Junior Member
Joe M.
Thanks again Joe the new motor was a breeze to replace as you had stated in your first reply, The fan blade was the only problem I had and after removing the spring clip and putting a squirt of wd-40 on the shaft it finally slid off without breaking. The new Samsung fridge fan motor is now running like the new one it is. Thanks so much
Frank(buckit)
Last edited by buckit : 03-03-2011 at 04:35 PM. Reason: Wrong last name initial for Joe M--Technician
  #8 (permalink)
Old 03-04-2011, 07:28 AM
Senior Expert
Default
Joe M.
Frank(buckit)
Frank,
I had a feeling you'd do fine,
We're glad you're up and running.
It was a pleasure to help.
Good Luck,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
motor replacement paksak Dryer Repair 0 07-30-2010 09:25 AM
Replacement motor shortarib Dryer Repair 1 02-05-2010 12:48 PM
Motor replacement dwr17200 Dryer Repair 1 09-08-2009 06:06 PM
motor replacement on Dw jpyra Dishwasher Repair 3 03-16-2009 07:21 AM
Motor Replacement Andre Filipe Washer Repair 17 03-15-2009 11:17 AM
