| » French Door freezer door mis-aligned |
Model Number: GI7FVCXWY02 Brand: Whirlpool Age: Less than 1 year
The left door of my Whirlpool french door fridge is slightly mis-aligned (too low), and I was told it could be raised by inserting a washer at the lower hinge. That door has both an ice/water dispenser and a touchscreen lcd display, so I'm a little leary of just diving right in...any help with removing the door would be appreciated. Also, if there's a common size washer that is used for this type of thing, please let me know.
dh Ads By Google Related Models |
Quote:
There's several things you should do first, Make sure the refrigerator is level in both directions, and all 4 feet/rollers are on the floor, solid. Check the freezer door for level side to side and that the freezer door panel, is level top to bottom. +++After that, if you need to, unplug the power cord or turn off breaker in box, you DON'T want this unit powerred up for the rest of the checks, repairs +++ Open the left door and remove the plastic hinge cover, you'll find the water supply tube and wire harness to the dispenser assembly, disconnect the tube(twist fit 1/4 turn CCW, and unplug harness). Remove the three screws holding the hinge to the cabinet top and lift door up and off the lower hinge pin. Check and make sure the lower hinge plate, is not bent or twisted. Here are some shims, you can use if needed: 67005716 Black / thick R9800056 Black / thin R9800058 White / thick These are older part numbers and may substitute over to a different part number, but they will work. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| LG French Door / Bottom Freezer Door Hinge Cam Broken - Looking for install procedure | ServicePlus | Refrigerator & Freezer Repair | 14 | 04-23-2011 10:45 PM |
| ge profile french door bottom freezer | brent pretzlaff | Refrigerator & Freezer Repair | 0 | 12-24-2010 10:19 AM |
| Maytag french door fridge freezer on bottom | lshamim | Refrigerator & Freezer Repair | 6 | 08-18-2009 08:14 AM |
| GE French door bottom freezer lights don't work | Carloppriori | Refrigerator & Freezer Repair | 1 | 06-13-2009 05:31 PM |
| LG- French Door Bottom Freezer is cold but refrigeration warm | ktmguy | Refrigerator & Freezer Repair | 6 | 01-16-2009 02:35 PM |
