Discuss
Ice forming in bottom of bottom mount freezer
 in
Refrigerator & Freezer Repair
I have a Maytag bottom mount freezer model # MBB1957VEW2 and the problem we're having is that ice is forming
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice forming in bottom of bottom mount freezer
  #1 (permalink)
Old 02-21-2011, 09:41 AM
Junior Member
gordow is on a distinguished road
Default Ice forming in bottom of bottom mount freezer
Model Number: MBB1957VEW2   Brand: Maytag   Age: 1 - 5 years
I have a Maytag bottom mount freezer model # MBB1957VEW2 and the problem we're having is that ice is forming on the bottom of the freezer and eventually it melts a little and runs out onto the floor.
I'm wondering if this water should be running into a drip pan or something and not forming on the bottom of the freezer.
We've tried adjusting the temp in the freezer to no avail , what it seems is that on the back wall where there is a vent to the freezer , condensation builds up and eventually rolls down into the bottom of the freezer and freezes up , and once in a while for whatever reason it starts to melt and runs out onto the floor.
Anyone have any suggestions?? Could it be a blockage and this "water" is not making it to the drip pan?
Thanks for all suggestions forthcoming.
Gord
Related Models
Maytag MBB1957VEW2 REFRIGERATOR
Maytag MBB1957WEB0 REFRIGERATOR
Maytag MBB1957WEB1 REFRIGERATOR
Maytag MBB1957WEW0 REFRIGERATOR
Maytag MBB1957WEW1 REFRIGERATOR
Maytag MBB2254GEB REF - BOTTOM MOUNTS
Maytag MBB2254GEQ REF - BOTTOM MOUNTS
Maytag MBB2254GES REF - BOTTOM MOUNTS
Maytag MBB2254GEW REF - BOTTOM MOUNTS
Maytag MBB2256GEB REF - BOTTOM MOUNTS
Maytag MBB2256GEQ REF - BOTTOM MOUNTS
Maytag MBB2256GES REF - BOTTOM MOUNTS
Maytag MBB2256GEW REF - BOTTOM MOUNTS
Maytag MBCM24FWBS00 WINE CELLAR
Maytag MBF1952VEW1 REFRIGERATOR
Maytag MBF1956HEB REF - BOTTOM MOUNTS
Maytag MBF1956HEQ REF - BOTTOM MOUNTS
Maytag MBF1956HES REF - BOTTOM MOUNTS
Maytag MBF1956HEW REF - BOTTOM MOUNTS
Maytag MBF1956KEB REF - BOTTOM MOUNTS
Maytag MBF1956KEB11 REFRIGERATOR
Maytag MBF1956KEB2 REFRIGERATOR
Maytag MBF1956KEB3 REFRIGERATOR
Maytag MBF1956KEB4 REFRIGERATOR
Maytag MBF1956KEQ REF - BOTTOM MOUNTS
Maytag MBF1956KEQ11 REFRIGERATOR
Maytag MBF1956KEQ2 REFRIGERATOR
Maytag MBF1956KEQ3 REFRIGERATOR
Maytag MBF1956KEQ4 REFRIGERATOR
Maytag MBF1956KEW REF - BOTTOM MOUNTS
Maytag MBF1956KEW11 REFRIGERATOR
Maytag MBF1956KEW2 REFRIGERATOR
Maytag MBF1956KEW3 REFRIGERATOR
Maytag MBF1956KEW4 REFRIGERATOR
Maytag MBF1958WEB0 REFRIGERATOR
Maytag MBF1958WEB1 REFRIGERATOR
Maytag MBF1958WES0 REFRIGERATOR
Maytag MBF1958WES1 REFRIGERATOR
Maytag MBF1958WES2 REFRIGERATOR
Maytag MBF1958WES3 REFRIGERATOR
Maytag MBF1958WEW0 REFRIGERATOR
Maytag MBF1958WEW1 REFRIGERATOR
Maytag MBF1958XEB0 REFRIGERATOR
Maytag MBF1958XEQ0 REFRIGERATOR
Maytag MBF1958XES0 REFRIGERATOR
Maytag MBF1958XEW0 REFRIGERATOR
Maytag MBF2254HEB REF - BOTTOM MOUNTS
Maytag MBF2254HEB14 REFRIGERATOR
Maytag MBF2254HEB4 REFRIGERATOR
Maytag MBF2254HEQ REF - BOTTOM MOUNTS
Maytag MBF2254HEQ14 REFRIGERATOR
Maytag MBF2254HEQ4 REFRIGERATOR
Maytag MBF2254HES REF - BOTTOM MOUNTS
Maytag MBF2254HEW REF - BOTTOM MOUNTS
Maytag MBF2254HEW14 REFRIGERATOR
Maytag MBF2254HEW4 REFRIGERATOR
Maytag MBF2255KEB REF - BOTTOM MOUNTS
Maytag MBF2255KEB11 REFRIGERATOR
Maytag MBF2255KEQ REF - BOTTOM MOUNTS
Maytag MBF2255KEQ11 REFRIGERATOR
Maytag MBF2255KEW REF - BOTTOM MOUNTS
Maytag MBF2255KEW11 REFRIGERATOR
Maytag MBF2256HEB REF - BOTTOM MOUNTS
Maytag MBF2256HEQ REF - BOTTOM MOUNTS
Maytag MBF2256HES REF - BOTTOM MOUNTS
Maytag MBF2256HEW REF - BOTTOM MOUNTS
Maytag MBF2256KEB REF - BOTTOM MOUNTS
Maytag MBF2256KEB11 REFRIGERATOR
Maytag MBF2256KEB2 REFRIGERATOR
Maytag MBF2256KEB3 REFRIGERATOR
Maytag MBF2256KEQ REF - BOTTOM MOUNTS
Maytag MBF2256KEQ11 REFRIGERATOR
Maytag MBF2256KEQ2 REFRIGERATOR
Maytag MBF2256KEQ3 REFRIGERATOR
Maytag MBF2256KEW REF - BOTTOM MOUNTS
Maytag MBF2256KEW11 REFRIGERATOR
Maytag MBF2256KEW2 REFRIGERATOR
Maytag MBF2256KEW3 REFRIGERATOR
Maytag MBF2258HEB REF - BOTTOM MOUNTS
Maytag MBF2258HEQ REF - BOTTOM MOUNTS
Maytag MBF2258HES REF - BOTTOM MOUNTS
Maytag MBF2258HEW REF - BOTTOM MOUNTS
Maytag MBF2258WEB0 REFRIGERATOR
Maytag MBF2258WEB1 REFRIGERATOR
Maytag MBF2258WES0 REFRIGERATOR
Maytag MBF2258WES1 REFRIGERATOR
Maytag MBF2258WES2 REFRIGERATOR
Maytag MBF2258WES3 REFRIGERATOR
Maytag MBF2258WEW0 REFRIGERATOR
Maytag MBF2258WEW1 REFRIGERATOR
Maytag MBF2258XEB0 REFRIGERATOR
Maytag MBF2258XEQ0 REFRIGERATOR
Maytag MBF2258XEW0 REFRIGERATOR
Maytag MBF2262HEB REF - BOTTOM MOUNTS
Maytag MBF2262HEB13 REFRIGERATOR
Maytag MBF2262HEQ REF - BOTTOM MOUNTS
Maytag MBF2262HEW REF - BOTTOM MOUNTS
Maytag MBF2262HEW13 REFRIGERATOR
Maytag MBF2556HEB REF - BOTTOM MOUNTS
Maytag MBF2556HEQ REF - BOTTOM MOUNTS
Maytag MBF2556HES REF - BOTTOM MOUNTS
Maytag MBF2556HEW REF - BOTTOM MOUNTS
Maytag MBF2556KEB REF - BOTTOM MOUNTS
Maytag MBF2556KEB11 REFRIGERATOR
Maytag MBF2556KEB3 REFRIGERATOR
Maytag MBF2556KEQ REF - BOTTOM MOUNTS
Maytag MBF2556KEQ11 REFRIGERATOR
Maytag MBF2556KEQ3 REFRIGERATOR
Maytag MBF2556KEW REF - BOTTOM MOUNTS
Maytag MBF2556KEW11 REFRIGERATOR
Maytag MBF2556KEW3 REFRIGERATOR
Maytag MBF2558HEB REF - BOTTOM MOUNTS
Maytag MBF2558HEQ REF - BOTTOM MOUNTS
Maytag MBF2558HES REF - BOTTOM MOUNTS
Maytag MBF2558HEW REF - BOTTOM MOUNTS
Maytag MBF2562HEB REF - BOTTOM MOUNTS
Maytag MBF2562HEB13 REFRIGERATOR
Maytag MBF2562HEQ REF - BOTTOM MOUNTS
Maytag MBF2562HEW REF - BOTTOM MOUNTS
Maytag MBF2562HEW13 REFRIGERATOR
  #2 (permalink)
Old 02-21-2011, 10:30 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
You'll need to remove the rear panel inside the freezer to expose the evaporator compartment. Right in the center is the drain tube, which you will probably find to be frozen or clogged with debris.
Pouring hot water into the drain, (Most of us just use a turkey baster, or something similar to do this.), will melt any frozen water in the drain. You should be listening for water running freely into the drip pan.
If it's clogged, use a bendable wire, like a wire clothes hanger, to push the clog through. Put a small loop on the end of the wire, so that you don't tear or puncture the drain tube.
  #3 (permalink)
Jeff / APP Team's Avatar
Senior Expert
Jeff / APP Team is on a distinguished road
Default
Your on the right track. You have a stopped up drain and it needs cleaned out. Remove the back wall of the freezer, and using hot water and a tube, blow out the drain line until hot water will flow freely through it. Hope this helps.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Jeff K. / APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #4 (permalink)
Old 02-21-2011, 02:52 PM
Junior Member
Default
When you mean the back wall panel or rear panel , do you mean from inside the freezer or the back of the fridge?
  #5 (permalink)
Old 02-21-2011, 07:18 PM
Senior Expert
APP Volunteer
Default
Inside the freezer.
  #6 (permalink)
Old 03-15-2013, 03:37 PM
Junior Member
mayerchakmr is on a distinguished road
Default
Okay, so I'm having the same problem that appears to be quite common! I'm ready to take this project on, but before I do, I'm wondering if it's possible to use compressed air or something to try and clear the drain tube from the bottom (and outside back) of the freezer instead of removing the inside back and clearing it from the top. What do you think?
If that's not possible/feasible, the one thing I'm concerned about is getting the drawer rails out - I know how to get the larger drawer out and the smaller basket, but the rails are going to need to come out as well to remove that inner back panel. I have a Whirlpool gold that came with the house in 2010.
  #7 (permalink)
Old 03-15-2013, 04:21 PM
Senior Expert
APP Volunteer
Default
What's your model number?
  #8 (permalink)
Old 03-16-2013, 02:17 PM
Junior Member
Default
Hello! The sticker inside says the model number is GI5FSAXVY02. Thanks!
  #9 (permalink)
Old 03-16-2013, 02:48 PM
Senior Expert
APP Volunteer
Default
It really isn't a good idea to blow compressed air INTO the freezer compartment. There may actually be some foreign matter in the drain tube, which, if blown into a fan motor, could cause it to fail.
I know it isn't fun to think about having to remove the drawer glides; especially if you have never done anything like it before. But a close examination will usually reveal how the parts separate for removal.
There are three common causes for ice build-up on a freezer floor:
1. Icemaker overfill (This will be self-evident).
2. Defrost failure
3. Physical drain tube blockage (Not ice).
Removal of the evaporator cover at the back of the freezer inner wall is the most expedient way to determine the cause of your problem.
  #10 (permalink)
Old 06-12-2013, 08:17 PM
Junior Member
Kjay2002 is on a distinguished road
Default
How do you determine the cause out of the three possibilities?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Inglis french door bottom mount? tomandals Refrigerator & Freezer Repair 5 07-23-2012 05:25 PM
Bottom mount freezer/fridge not cooling Properly Gwaii Refrigerator & Freezer Repair 3 04-10-2009 12:52 PM
Kichen Aid bottom mount Fridge/Freezer - not cooling lbjgh Refrigerator & Freezer Repair 1 06-11-2008 05:10 PM
frost forming in bottom freezer compartment Betty Refrigerator & Freezer Repair 0 08-22-2007 06:48 AM
