I have a Kitchen Aid Superba refrigerator and the water dispenser in the front door is leaking water. From various research, it's stated that there's a few possibilities. 1) There is air trapped in the system/tube. I've ran water through 4-5 glasses and the problem still persists. 2) The water valve inlet needs to be replaced as the valve may not be sealing properly.
If my issue is related to number 2, can you let me know the replacement part number. If not, what other issues can it be?
Thanks!
