Replacement parts for FRIGIDAIRE FRS26KR4CQ1 Frigidaire/refrigerator | AppliancePartsPros.comHere is the tech sheet
http://manuals.frigidaire.com/p...f/Anderson/240389613.pdfWhen the units is set to a temperature does the compressor come on and does it cycle on/off?
From your post I get the impression that the compressor does run.
If it runs continuously then you probably have a sealed system or a defrost problem.
Unplug the unit and remove the evaporator cover from inside the freezer so you can see the coils.
If they are heavily frosted/iced over then you have a defrost problem.
If there is no frost or just frost in one area then it is probably a sealed system problem.
If a defrost problem try forcing a defrost cycle, see the tech sheet.
Do not manually defrost them.
If they are heavily iced/frosted over you have a defrost problem.
The fans and compressor will turn off when in a defrost cycle.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer/board needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer/board is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
If it is a sealed system problem, the repair will be expensive as you will need a pro. Also there is no guarantee on a long term fix. It usually makes more sense to put the dollars into a new unit.
Check your warranty as many units have a longer sealed system warranty.
