Turned off thermostat to clean the freezer.turned thermostat back to original setting now nothing turns back on. can you please help in this matter.
Does it make any sounds? Do the fans work? If not then locate the hole on the bottom of the control box on the right side. This hole leads to the defrost timer (#6 on the diagram) shaft. Using a flat blade screwdriver, turn the shaft CW for about 180°. If the compressor start, replace the defrost timer. If it did not start, unplug the refrigerator. Open the control panel, remove the wires from the thermostat and check for continuity across the thermostat terminals while the thermostat is on. If there is no continuity, replace the thermostat. - The defrost timer Part number: AP3110896
