mnowlan
#1 Posted : Wednesday, February 16, 2011 4:43:10 AM(UTC)
mnowlan
For about a month now our refrigerator will not defrost. About 2 weeks ago I emptied the freezer and removed the panel to get access to the coils and used my heat gun to defrost the freezer. The last couple of days we noticed the refrigerator not cooling again. I checked, and sure enough the coils were all covered in frost again. I just finished defrosting it again.
What causes the freezer not to defrost and what fix is there to get the freezer to defrost like it is suppose to?
#2 Posted : Wednesday, February 16, 2011 5:49:41 AM(UTC)
Your model number looks short a couple digits, so I used GHW2 they will all be very close to each other.
Replacement parts for FRS26ZGH models | AppliancePartsPros.com
Here is a wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/218909400.pdf
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
Manually force a defrost cycle by turning the defrost timer cam (Item 23 in Section 5) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 14 in Section 6) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 21 in Section 6) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
supresmooth
#3 Posted : Tuesday, May 15, 2012 8:33:02 PM(UTC)
supresmooth
denman, I followed your instructions a bit. I found that the heating element turned on when I manually initiated the defrost by turning the timer to the right spot. I replaced the timer and it seems to do its thing, properly turning off the compressor and turning on the element. However, it seems my coils are still frosting over.
I have a Frigidaire FRS26ZRFW2. The freezer gasket seems a bit wonky on the bottom inside corner, but it's ~$100 to replace it. Is that really a likely culprit? Should I try replacing the thermostat anyway/first? The frost itself seems . . . weird. Like, fake frost almost. I am worried about a freon issue, as I definitely can't afford a new fridge right now. All of this ice keeps plugging up the cool air portal and ruining my food, though. I am tired of hair drying my coils to save my lunch.
Thanks for your expert advice.
#4 Posted : Wednesday, May 16, 2012 2:43:11 AM(UTC)
supresmooth
[COLOR="DarkRed"]
The freezer gasket seems a bit wonky on the bottom inside corner, Is that really a likely culprit? Should I try replacing the thermostat anyway/first?[/COLOR]
The gasket could be the problem especially if you live in a humid part of the country.
Take a 2 inch strip of paper and place it between the door seal and the frame then pull it out to see if it is sealing correctly. Works your way around the door checking every 6 inches or so.
A common problem is the seal grabbing and twisting on the hinge side. A light coating of vaseline or white lithium usually fixes this.
Could also be the thermostat. Get a thermometer and monitor the freezer temperature.
I am assuming you mean the main thermostat and not the defrost thermostat.
[COLOR="DarkRed"]I am worried about a freon issue, as I definitely can't afford a new fridge right now.[/COLOR]
I am very doubtful that it is a freon problem, wrong symptoms for this.
Low freon will cause the unit to run either continuously or a lot more than it used to.
supresmooth
#5 Posted : Sunday, September 30, 2012 7:16:50 PM(UTC)
supresmooth
I went ahead and replaced the freezer gasket and did the thin coat of Vaseline. I let the freezer defrost completely so I could make sure it was the issue.
That did not solve the over-frosting problem. Because the defrost thermostat and the temperature control were relatively affordable, I opted to do them both at the same time. I am not sure which one was the issue, but replacing those items resolved the issue entirely and my freezer and refrigerator now work just fine.
Thanks for your help. In all, parts and materials ran me about $115. I consider that quite an affordable repair compared to calling someone out.
The hardest part of the replacement was the connections for the new defrost thermostat. The connectors had corroded some and the new part did not come with connectors on it, just wires. So I needed to clamp and shrink-tube the new connections. The included shrink-tubing was too short to enclose the included connectors, so I needed to go to the store to buy longer pieces of that. Also, it was impossible to shrink the tubing without a proper heat gun (a hair dryer will not work, wah wah), but I was able to borrow one of those. I made sure to follow the directions and include the "drip loop" for the wires leading to the unit to avoid condensation leaking into it.
The temperature control has simple connectors and is just a swap out, but I recommend others that do this write down which colors connect to which places on the unit. I thought I could remember it in my head, but I forgot, and then had to spend 45 minutes online trying to find a picture of the whole section for comparison.
#6 Posted : Monday, October 1, 2012 2:19:11 AM(UTC)
Glad to hear you have it fixed.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
For future reference.
You could have used a couple wire nuts to connect in the defrost thermostat.
I like to used the hard black plastic (bakelite) type as the have more temperature tolerance.
Keep the wires long enough so that you can attach them over to the side and so that the wire nuts face down (stops water getting into them.
Some follks also like to seal them with some silicone as an extra protection.
Freezer won't defrost (Refrigerator & Freezer Repair)
by ctomlinson 3/26/2016 3:43:13 PM(UTC)
whirlpool freezer won't defrost (Refrigerator & Freezer Repair)
by JEschCO 6/24/2012 12:12:12 PM(UTC)
by Rdewees 4/27/2012 10:40:22 AM(UTC)
Freezer won't defrost on it's own. (Refrigerator & Freezer Repair)
by berhiet 4/26/2012 10:17:22 AM(UTC)
by czhaiku@gmail.com 2/16/2012 6:04:59 AM(UTC)
by golfersteve 4/29/2010 3:37:46 PM(UTC)
