Heard a loud grinding sound from my fridge on Saturday early evening. On Sunday evening found puddle of water in front of freezer. Everything thawing in freezer. Checked temp control and freezer turned down to 3. Emptied freezer turned up temp control, put bowl of water in freezer and still just a bowl of water at 7am on Monday. Refrigerator doesn't feel very cold either.
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Thanks for your post. It ended up being a relay switch that turns on the compressor.
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause. |
